Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 21, 2010, 10:01 AM
Mnpctech's Avatar
Default Custom Laser Cut PC Window
Custom Laser Cut PC Window with Modder’s Mesh!
Custom Laser Cut PC Window with Modder's Mesh. | Case Mod Blog
Old July 21, 2010, 10:18 AM
Arinoth's Avatar
That is just amazing, as always
Here I am: here I remain
Old July 23, 2010, 01:23 PM
Mnpctech's Avatar
Thanks for checking it out Arinoth
Old July 23, 2010, 02:54 PM
gingerbee's Avatar
wicked who's bulldog,truly great as always. mnpctech if not the best modding shop what is?? ha ha
Old July 24, 2010, 09:35 AM
Mnpctech's Avatar
It was for Gruntville.com ahwile back
If you want a quote for laser cutting your PC panels, you can submit a DXF file of your design to iandhATihacc.com (replace AT with @)
Would my 550w cut it? curtispan Power Supplies 7 December 21, 2009 04:47 PM
How do you guys cut your hose? rai_polo Water Cooling 30 November 2, 2009 12:51 AM
Antec Tricool - Cut or not cut? Lol misterhelpmeplease Guides & How-to's 6 May 21, 2009 02:15 PM
what tools do I need to cut some holes? Shadowmeph Water Cooling 2 January 4, 2009 04:53 PM
Another AMD price cut Babrbarossa CPU's and Motherboards 8 October 11, 2007 01:34 AM
