Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old June 26, 2010, 08:44 PM
bkh2's Avatar
Default Powering Everything Off Via Power Bar Every Night
I'm not exactly sure where to post this, but I have a question:
I have all my computer stuff hooked up to one power bar and every night, after I shut down, I also turn off the switch on the power bar. This cuts out all power so the lights on the mobo as well as any connected peripherals (such as a USB hub) are off. My question is whether this is bad for the overall longevity of the computer, whether it has any adverse effects, or whether it is actually a good thing to do. Any insight would be greatly appreciated. Thanks!
Old June 26, 2010, 09:08 PM
Pine's Avatar
Well, I'm not sure if it's good or bad, but I keep the powerbar itself always on.
Old June 26, 2010, 09:09 PM
supaflyx3's Avatar
No why would it be bad? The only adverse effect i see is the HDD's use alot of power to spin-up, so that decreases their longevity. Other then that you should be fine.
Old June 26, 2010, 09:12 PM
bkh2's Avatar
Do you mean to say that the HDD's spin even after the computer has shut down?
I've read a little bit on this and people seem to say different things. Some say that it'll generate power spikes which may damage the power supply, and in turn will damage the rest of the components. Others say it is totally fine.
Old June 26, 2010, 09:20 PM
It's not a problem, and you actually save on standby power by doing it.
Old June 26, 2010, 09:24 PM
supaflyx3's Avatar
No i mean when you start your computer up in the morning the HDD's use a lot of power to spin-up.
But i agree with zero, even if you turn off your computer it's still drawing power, so in turn it's saving you money with turning off the powerbar.
Old June 26, 2010, 09:25 PM
bkh2's Avatar
Yeah, saving power was the main reason. My dad, being as cheap as he is, told me to hook everything to one and turn it off at night to save power lol
I guess as long as there are no adverse effects, I am okay with it. Should prevent my comp from getting destroyed in the event of a lightning storm too haha
Old June 26, 2010, 09:37 PM
supaflyx3's Avatar
no it wouldn't -.- if lighting struck, it would still go straight to your computer.
Pine's Avatar
Hmm, guess I'll start turning my power bar off too. Why would my rig be sucking power when it's off?
Old June 26, 2010, 09:40 PM
supaflyx3's Avatar
Standby power - Wikipedia, the free encyclopedia
Power Bar Noise ZereoX Troubleshooting 5 March 14, 2010 02:10 PM
recommend a bar/pub in montreal... omgwtf Off Topic 18 October 3, 2009 04:14 AM
PC not powering up yamawho Troubleshooting 5 January 14, 2009 03:20 PM
Strange SLI bar kruzn4evr Troubleshooting 18 December 12, 2008 08:48 AM
PC not powering up neyjunior Troubleshooting 6 June 7, 2007 01:17 PM
