<~----> Powering Everything Off Via Power Bar Every Night - Page 3 - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old July 1, 2010, 10:49 AM
Originally Posted by Digikid View Post
Switching off the power bar is a bad thing to do. It can "spike" your computer and damage it. Also you are shortening the life of your CMOS battery as it needs a constant stream of juice to keep it at peak.
Switching off a power bar does not create a spike. And the CMOS battery is not rechargeable. There is no power supplied to it.
  #22 (permalink)
Old July 1, 2010, 11:15 AM
Arinoth's Avatar
I guess its time for me to contribute to this thread.
Switching off a power bar does not create a spike at all because you are going from a voltage/current level to nothing.
Switching on a power bar DOES create a spike as you are going from nothing to a steady voltage/current. The spike though is the equivalent of plugging your unplugged device into a wall, it is designed to handle this surge. Also, a good surge protector will not allow this small spike to reach the outlets/plugs and will keep it contained.
Running a device all the time is typically better then constantly turning it on and off since that is where a lot of electrical spikes happen, whenever you turn on a device there is a spike, nothing goes from 0 to 5V (even in DC), you go from 0 to 6 to 4.5 to 5V (as an example). In electronics its called going from unsteady state to steady state, this typically can last a few milliseconds to several seconds.
Though as i stated before, most if not all electronic devices if they are well designed/made are designed to handle these little spikes when being plugged in/turned on. Its why cheaply made stuff goes quickly if you turn it on/off a lot rather then keeping it constantly on.
  #23 (permalink)
Old October 31, 2010, 12:52 PM
Default power bar
check those apc surge protector
APC Power-Saving Essential SurgeArrest 7 outlet, with phone line protection, Canada, 120V
  #24 (permalink)
Old October 31, 2010, 12:56 PM
Did you really need to revive this old thread? :\
Power Bar Noise ZereoX Troubleshooting 5 March 14, 2010 02:10 PM
recommend a bar/pub in montreal... omgwtf Off Topic 18 October 3, 2009 04:14 AM
PC not powering up yamawho Troubleshooting 5 January 14, 2009 02:20 PM
Strange SLI bar kruzn4evr Troubleshooting 18 December 12, 2008 07:48 AM
PC not powering up neyjunior Troubleshooting 6 June 7, 2007 01:17 PM
