Well looking at these, and never having made molex plugs before, I don't really know how one goes about using these:
A.C. Ryan Connectx MxF Connector & Pin Set - 10x - Black Products Model: ACR-CB00038 [ACR-CB00038] : Performance-PCs.com, ... sleeve it and they will come
I'm guessing I could just solder the wire into the middle area? I notice that with typical molex though, you can crimp them. Is that necessary for these?
Also what gauge wire would you suggest? 18AWG or 22AWG? Just going to be for my pump, fans/fan controller and maybe my DVD-RW. Right now it's a total hackjob, all the wires are just twisted together so obviously I want to fix that up
