How Do You Apply Thermal Compound? Hello! I am a beginner builder and was wondering how to put thermal compound onto the CPU? There are two methods that I have learned, but I people have said both methods have advantages and disadvantages. Pea Method: Apply pea-sized blob on the center of CPU and then put on the heatsink. Spread Method: Apply blob of compound, spread over whole top of the CPU. Which method is better? Or is there an even better method? All help is appreciated. |
Pea blob is best, since the pressure from applying the heatsink will spread the paste, leaving no space for air bubbles to form. Unless you have a HDT (Heatpipe direct touch) cooler, then some say it is better to do the 2nd method since it fills in the cracks better. |
like Jake_HT said, a pea sized dot, and put the heatsink down and it'll spread it. |
Use the better methods listed in this article depending on what kind of heatsink you have: http://benchmarkreviews.com/index.ph...d=170&Itemid=1 |
As I don't disagree with the members above, no bigger than pea size, from my experience half a pea size works best for me because 1) it enough to cover the CPU when heatsink is installed and 2) not too much to spill over causing a mess. All the best! :thumb: |
I would have to say that the x method is the best but pea is the easiest. |
I randomly just end up doing one or the other with out really thinking lol. |
Pea method for me. Amount depends on which paste Im using. For example you need much less AS5 than that diamond stuff. |
i used to spread, now i pea. that sounds kinda awful |
Pea method mostly but for naked chips I still spread....unless it is ic7 then pea is the only option.:angry2: |
| All times are GMT -7. The time now is 06:52 PM. |
