Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #31 (permalink)
Old January 23, 2011, 02:16 PM
Hmm...that link to benchmark reviews is very interesting and I've seen it before. The HDT method of filling in the crevasses with a little room left on top, and then applying lines between the pipes looks solid. I have a pair of Vendetta 2s to mount so I'll give it a go. The only problem is, it looks like it'll be a nightmare to clean up when replacing the TIM...getting all that packed in and caked on goo goodness out of the channels.
AS5 doesn't exactly clean easily either, it's funny that I still haven't run out yet, I've watched MX-2 through MX-4 come out with curiosity haha.
  #32 (permalink)
Old January 27, 2011, 01:55 PM
Exlibris's Avatar
I always tell myself to use the pea method, and then I can't help but think I need two, then three, then four, or five peas. In the end I guess what matters is only that no goop gets in the pins or on the mobo.
  #33 (permalink)
Old January 31, 2011, 02:24 PM
This is quite a debate, I've always done the finger method and never had issues where you spread it completely then a few years ago I learned how bad it was to have your bare finger doing that (for your body), then I started doing the card trick seemed to work fine think I might try this pea trick though I guess see what happens as long as I dont damage the CPU I'm happy!
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
  #34 (permalink)
Old January 31, 2011, 02:29 PM
SugarJ's Avatar
I've always done the X myself, except on HDT heatsinks with an uneven base. It's always produced an even spread for me.
  #35 (permalink)
Old January 31, 2011, 03:47 PM
Fudd Rucker's Avatar
I did the smiley face method, now im not sure if its just my new chip or what but my temps are about 15 degrees cooler under load. And ive got a signifigantly higher clockspeed and voltage, not to mention 4 threads being added to the mix.
I couldnt think of something snarky or interesting to put here this time around.
  #36 (permalink)
Old February 1, 2011, 01:22 PM
I tried both line method and pea drop...both didn't really seem to make a huge difference...pea drop uses less and is easier to apply, that's for sure, lol...
  #37 (permalink)
Old February 1, 2011, 01:34 PM
Usually two small fat lines side by side, or with a HDT I smush paste into the gaps and apply one dot on each of the middle heatpipes.
With the diamond paste I just put a big blob in the middle (usually only use it with water blocks).
heatware
  #38 (permalink)
Old August 18, 2011, 02:24 PM
Thought I would report back, been using the pea method lately probably done it about 40 times now and I'm liking it temps are good and when I take it off it seems like the spread is even and what not.
  #39 (permalink)
Old August 21, 2011, 08:33 AM
southbay's Avatar
What I do is place a small amount on the cpu, take a plastic bag then wrap it around my finger and spread. This way you can feel if the compound is uneven and it's fun for all the family!
Corsair 550d
Intel i5 Quad Core 2500k @4ghz
GTX 570
Asus
Corsair HX 750W
G.Skill sniper 2x4GB
OCZ Agility Series 60GB SSD
  #40 (permalink)
Old August 23, 2011, 04:28 AM
Your_friendly_gamer's Avatar
That is pretty good thinking, I will try that next time.
Thermal Compound homer98 Water Cooling 10 March 9, 2010 05:52 AM
How much thermal compound? 4DoorGTZ Overclocking, Tweaking and Benchmarking 16 April 2, 2009 07:15 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 05:17 PM
What is the best way to apply thermal compound to the Vendetta 2? lowkey Air Cooling 0 August 17, 2008 09:52 PM
How to properly apply thermal compound Corpus Masochist CPU's and Motherboards 9 August 11, 2007 08:12 AM
