Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old January 4, 2011, 01:22 AM
da_bradler
Guest
Posts: n/a
I use a business card to apply as thin a layer as I can achieve directly to the heat spreader on the CPU. I still don't understand why the pea method would be better.
  #22 (permalink)
Old January 4, 2011, 03:46 PM
YouTube - How Thermal Compound Spreads
Personally, I go with the pea-size method. As you can see from the video, spreading the thermal paste actually increases the chance of creating air bubbles.
  #23 (permalink)
Old January 6, 2011, 02:03 AM
Apathetik's Avatar
Smile method for the win :-D (@ 2:34)
ASUS VE278Q 27" LED / DAS Professional Model S Cherry MX Blue Mechanical / Logitech G500 - QcK Mass / Corsair Veng 2000 / Windows 7 Ultimate 64bit
  #24 (permalink)
Old January 7, 2011, 01:42 PM
Slaughter's Avatar
Tried it out of curiosity last night.. Excellent results. Great coverage. And definitely cleaner than the spread technique I was using. Temperatures are right on the mark.
  #25 (permalink)
Old January 10, 2011, 01:40 AM
Apathetik's Avatar
Good to hear Slaughter!
  #26 (permalink)
Old January 10, 2011, 06:29 PM
ykcorey's Avatar
What about the lifespan of thermal paste after it has been used? I've worked on older computers and it looks like something died underneath the hsf.. should you worry about it after a few years? I never have, but looking at old computers with crust covering the cpu makes me worry about my own computer.
  #27 (permalink)
Old January 10, 2011, 06:48 PM
Slaughter's Avatar
I can't really say as I usually upgrade within a year... And the odd computer I don't upgrade, I usually change the thermal paste once a year.
  #28 (permalink)
Old January 10, 2011, 07:35 PM
ykcorey's Avatar
  #29 (permalink)
Old January 11, 2011, 06:29 PM
Pea method!
  #30 (permalink)
Old January 22, 2011, 04:18 AM
I used to spread it across the chip, now I just use the Pea method.
Thermal Compound homer98 Water Cooling 10 March 9, 2010 05:52 AM
How much thermal compound? 4DoorGTZ Overclocking, Tweaking and Benchmarking 16 April 2, 2009 07:15 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 05:17 PM
What is the best way to apply thermal compound to the Vendetta 2? lowkey Air Cooling 0 August 17, 2008 09:52 PM
How to properly apply thermal compound Corpus Masochist CPU's and Motherboards 9 August 11, 2007 08:12 AM
