Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 7, 2010, 11:54 AM
Originally Posted by rip10793 View Post
I would have to say that the x method is the best but pea is the easiest.
I have been told that that the X method provides less than ideal results. I then proceeded to use my google-fu to find out which application method works best for different types of coolers. Here is one of the best TIM application guides I could find which comes from benchmark reviews. They have a wealth of information and I consider their reviews to be of the same calibre as HWC reviews. They say a picture is worth a thousand words, so here they are.
http://benchmarkreviews.com/index.ph...d=170&Itemid=1
Old July 7, 2010, 02:14 PM
geokilla's Avatar
All depends on your cooler. HDT coolers perform best when you place strips of thermal compound in between the heatpipes. Normal flat base coolers perform best with the pea method.
Old July 7, 2010, 02:30 PM
jcmaz's Avatar
That's what i do to my HDT cooler.
-Plato
Old July 8, 2010, 04:21 PM
Smoothie's Avatar
Pea size is way too large, maybe about 1/3 of a pea size you should place in the center.
Old July 20, 2010, 05:38 AM
patpond's Avatar
inchworm for me,
I forget where exactly I read this, but have heard that the heat from a CPU starts in the middle of the chip and spreads (mostly) up and down. So I put a thin stripe in the middle up and down (leave room at the top and bottom for expansion of paste). Now, I may be wrong, but it works for me .
wtf is a Signature?
Last edited by patpond; July 20, 2010 at 06:26 AM. Reason: left an important part out
Old July 20, 2010, 06:01 AM
pea method and rotate the hsf 180 degrees
Old July 23, 2010, 04:33 PM
m4Dm4xx's Avatar
Thank's for the benchmark link, some good info there
I have always made an X out of 5 dot's, seem's to work well for me? Guess i should yank the cooler to see what contact patch is like?
Old August 21, 2010, 06:14 PM
Yep, depends on the cooler + compound. HDT coolers work best with the double line technique. The pea or the X are good for square bases. Some compounds spread easier than others, thus requiring less tim. Best bet is to mount the HS, then take it off. Verify the coverage and adjust as necessary. Don't be a tightass, thermal compound is cheap.
  #19 (permalink)
Old August 30, 2010, 12:33 AM
Jokester's Avatar
Used to spread it, now I mostly put a BB amount seems to be the same difference in temps.
Techead in mind, body and soul
Lian Dream: i7 2600k @ 5.1Ghz, Asus Maximus IV Gene-z, MSI N580GTX Twin Frozr II,8GB 2x4GB Mushkin Ridgeback, Crucial M4 128GB x2, Plextor PX-755SA, Seasonic 750, Lian-li
HTPC: E5300@3.6ghz, Asus P5Q Pro Turbo, Gigabyte 7600GT, Mushkin redline 1GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, PC P&C 510, Silverstone LC16m
  #20 (permalink)
Old January 3, 2011, 01:25 PM
Slaughter's Avatar
I used to use a pea sized amount on the die of Socket A cpus, but when I moved to a current generation, I started to spread it. Don't know why.. but just wanted to ensure it had full coverage. Never an issue with it spilling over either.
Thermal Compound homer98 Water Cooling 10 March 9, 2010 05:52 AM
How much thermal compound? 4DoorGTZ Overclocking, Tweaking and Benchmarking 16 April 2, 2009 07:15 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 05:17 PM
What is the best way to apply thermal compound to the Vendetta 2? lowkey Air Cooling 0 August 17, 2008 09:52 PM
How to properly apply thermal compound Corpus Masochist CPU's and Motherboards 9 August 11, 2007 08:12 AM
