Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 6, 2010, 06:33 PM
Default First things you do when you start up a new build?
Well my build should be here tomorrow and its pre-built by NCIX. What do you suggest are the first things I do? I know some of you may preform certain tests on your computer to see if everythings functioning properly, also disabling some features in the OS to ensure maximum performance? Just small things like that, what do you guys do and think I should do to ensure I dont screw up?
Thanks
Old May 6, 2010, 06:39 PM
Lpfan4ever's Avatar
Push power button.
Originally Posted by encorp
Code:
<firebane> slightly used
Old May 6, 2010, 06:41 PM
ZZLEE's Avatar
Default VIrrus protection
Dounload onto a USB stick or disk from someware like CNET Virus program and malware program with your present computer and get them on it first thing. What did you buy list us out a speck sheet. Image the OS with an imaging program to anouther disk or partition.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 6, 2010, 06:58 PM
gingerbee's Avatar
for "P built" makes sure all the fans spin. then go to Ninite Easy PC Setup - Silent Unattended Install Multiple Programs At Once
Old May 6, 2010, 06:59 PM
CMetaphor's Avatar
Quadfather
Crack open a beer and rejoice after it posts. lol
Old May 6, 2010, 07:18 PM
Yeah, I got a Win7 32 bit .iso already on my bootable USB.
I got this:
GB P55-usb3 atx LGA1156
XFX 5770
i5 750
gskill 4gb core i5 1.5v mem kit
coolermaster storm sniper baby ;)
seagate 500 gb (i dont use alot of space :P)
corsair pro HX650W
g15 keyboard
random surge protector ;)
Old May 7, 2010, 12:52 PM
Alpine's Avatar
push the power button and cross finger....
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old July 15, 2010, 05:06 PM
You should jump in your bios and check your temps. Make sure air is flowing and the heatsink is mounted correctly. Then make sure all your stuff is being detected, ie: hdds, dvd drive, ram, cpu. Then set your boot priority and get on with the os install.
Old July 15, 2010, 05:10 PM
stoanee's Avatar
mmm.......beer
heatware
Old July 15, 2010, 07:06 PM
dustin1706's Avatar
Haha, nice two month revival fenix.
I read about this site Ninite Easy PC Setup - Silent Unattended Install Multiple Programs At Once in another forum. I dunno how it works exactly... but I plan on giving a try on my next reformat/build. Also, it's always a good idea to let your computer run for at least a few hours to let the thermal paste set before OCing.
problems with new build start up - HELP!!!! tap77377 Troubleshooting 11 April 19, 2010 06:19 PM
Things to do When You Build a New Computer crispex New Builds 19 March 31, 2009 01:35 AM
New Build - Will Not Start - Help! Modestyle Troubleshooting 14 March 12, 2009 08:01 PM
New Build, won't start shryke Troubleshooting 17 October 23, 2008 03:42 PM
New build wont start at all Psycho-Designs Troubleshooting 19 April 14, 2008 01:08 PM
