Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 19, 2010, 01:45 AM
Prolab's Avatar
Originally Posted by gingerbee View Post
for "P built" makes sure all the fans spin. then go to Ninite Easy PC Setup - Silent Unattended Install Multiple Programs At Once
Ninite is a pretty cool utility. Im just curious, does it install everything unto one partition/directory? Or does it give you the option of installing the programs unto a specific partition/directory?
Old July 19, 2010, 02:45 AM
Remove all the packing from inside the case, make sure nothing loosened off in shipment, power up. They typically run some benchmarks after assembly so you should see 3DMark06 or something like that, they do a very good job as I just broke down and had them assemble my last build.
Cheers; Snarl
Another Guy From Canada
Old July 19, 2010, 08:36 AM
SugarJ's Avatar
It's an auto-installer for the available programs. Each program gets installed into its default directory.
I've used it lots, it works very well.
Old July 19, 2010, 10:29 AM
gingerbee's Avatar
I use it or Quick & Easy PC Setup for Windows XP - Allmyapps every other day they work great.
problems with new build start up - HELP!!!! tap77377 Troubleshooting 11 April 19, 2010 06:19 PM
Things to do When You Build a New Computer crispex New Builds 19 March 31, 2009 01:35 AM
New Build - Will Not Start - Help! Modestyle Troubleshooting 14 March 12, 2009 08:01 PM
New Build, won't start shryke Troubleshooting 17 October 23, 2008 03:42 PM
New build wont start at all Psycho-Designs Troubleshooting 19 April 14, 2008 01:08 PM
