Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 20, 2010, 11:47 AM
Default How to set up 4 SSD's ?
I am building a new system soon for school and was wondering if anyone could list the steps I will need to do to install these. I have put 2 comps together before but never SSD's or raid
I am getting this mobo here Newegg.com - ASUS P6T7 WS Supercomputer "Ultimate Gamer" choose 3Way SLI + PhysX at Real X16 X58 CEB Intel Motherboard - Intel Motherboards
and 4 of these Newegg.com - OCZ Agility Series OCZSSD2-1AGT60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD) - SSD
I want 1 to be for OS(win7) another by itself and 2 in a raid 0
Old March 20, 2010, 12:11 PM
lowfat's Avatar
It is really easy. In the bios you need to set your SATA ports to RAID. Then when it prompts the RAID bios on boot, hit the keys used to enter it (usually CTRL+I). Then select the drives you want to add to the RAID. Select 128k as your stripe size. Then just install your OS.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old March 20, 2010, 12:23 PM
I don't need to do aligning or any of that stuff I kept reading about for the SSD's ?
Old March 20, 2010, 12:30 PM
Perineum's Avatar
That's quite the "school" computer.... I would almost guess that's overkill for a spreadsheet or word document
Old March 20, 2010, 12:31 PM
lowfat's Avatar
You only need to do partition alignment w/ Windows XP.
Old March 20, 2010, 12:38 PM
Yes I am going a bit crazy with it. http://secure.newegg.com/WishList/Pu...umber=12464665
Oh I did not know that lowfat , thank you .. I hope it goes as easy as you make it sound D:
Old March 20, 2010, 01:25 PM
Perineum's Avatar
Who the hell is paying for it? I'm guessing you aren't.....
Have you built a computer before? Not to be insulting but I'm guessing you haven't. Maybe I'm wrong.
I don't see a video card in that list, either...
And what the hell are you doing with that system?
Old March 20, 2010, 01:31 PM
Sushi Warrior's Avatar
Yes I am going a bit crazy with it. Newegg.com - Once You Know, You Newegg
1. BFG PSU? I would go for a Corsair HX850. Don't think you need 1200w either....
2. All that in an Xclio case.... well I suggest at least a CM 690II but preferably something like a Silverstone RV02.
3. Wouldn't getting 3 Intel X-25M's be better? I don't think you want SSD's in RAID anyways, you lose TRIM....
4. RAM seems awfully cheap.
5. Is an i7 980X REALLY needed? An i7 930 should be plenty....
6. What GPU's?
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old March 20, 2010, 01:43 PM
No I am paying for it... with loans and yes I have built 2 before. Its for rendering / video editing
Is it really bad to raid them ? I will have a look at those you mentioned instead I just remember they were more expensive
I went with cheap ram cause I had to cut somewhere.. but really wanted 24 gigs for video editing epically.
The GPUs is what I am waiting for , I want to get one of the gtx 480's due out in a few days
Old March 20, 2010, 02:35 PM
gingerbee's Avatar
no it's fine to raid them i would still do some tweaks and that's just me. Windows 7 - Ultimate SSD Speed Tweaks
how does this look for a set up. kyle_L Water Cooling 8 December 19, 2009 05:53 PM
[WTB] I7 Set-up Chromey Buy/Sell & Trade 5 October 20, 2009 07:35 AM
2.1 set Josef Audio 5 June 26, 2009 06:31 AM
Help on Raid set-up Malam Storage 4 December 9, 2008 02:13 AM
sata set up Rapid-X Storage 2 September 2, 2007 09:24 PM
