Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old October 22, 2007, 12:04 PM
Cptn Vortex's Avatar
Default Cleaning RAMchips and other surfaces
So i did some experimenting, and thought I would give you my findings. I used to be lazy, and just use papertowell, which worked OK. Then I started getting more concerned with the best possible contact, so started with Rubbing alcohol and coffee filters. That method worked perfect, until I took the cooler off my 8800GTX, and had to clean those pesky RAMchips! After fighting and fighting with them, I finnaly pulled out an old microfibre cloth from a pair of sunglasses, to give it a try. To my amazment, with only a little rubbing alcohol, it cleaned them up perfectly in no time. What a difference the cloth makes!
In conclusion, coffee filters are great for CPU's and heatsinks, but no match for the microfibre cloth when it comes to chipsets and ram! If you have any other methods, enlighten us!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old October 22, 2007, 12:07 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I use alcohol wipes for everything. The ones that come with the lil cloth like a wetnap intended for cleaning lcds and such.
Old October 22, 2007, 12:13 PM
Ah smart! How long do they last? Cause I would think they would tear and break apart after a few chips?
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old October 22, 2007, 01:18 PM
Eldonko's Avatar
They are 1 use, I have a big box of em individually packaged.
Old October 22, 2007, 01:45 PM
Babrbarossa's Avatar
Man- those mosfets and ramsinks on the 8800's are hell- the TIM one the stock GPU coolers use must be pretty damned greasy because I cleaned and cleaned last time with 100% alcohol and still couldn't get all of the heatsinks to stick. That's why I just bought a full coverage stealth- tired of those little buggers falling off everytime I swap some parts out. I know I could've used the adhesive but I'd like to be able to RMA the card if I had to. Funny though- the newer Swiftech mosfet sinks have a silver sticky TIM instead of the white stuff they had before- must be an improvement because they stick pretty good.
psst, wanna see my binder?
Old October 22, 2007, 02:06 PM
Yah, at first I attached the ramsinks with the stiky pads they had, but they just would not stick. Got some Arctic adhesive, they're not going anywhere now!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old October 22, 2007, 02:07 PM
sswilson's Avatar
AFAIC nothing, and I mean nothing cleans hard-to-reach surfaces better than a good soaking with an aerosol contact cleaner. Probably not the most environmentally friendly solution, but it does seem to do the trick.
Old October 22, 2007, 02:52 PM
Eldonko's Avatar
Yeah, electronics cleaner is what I use on boards usually. Tools for the sub zero bencher:
Old October 22, 2007, 07:13 PM
Patriote's Avatar
Arctic clean, Q-tips (Cotton swabs) and paper towel. Thats what i always used and it always worked fine.
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old October 22, 2007, 07:26 PM
Ah-- liquid electrical tape- does that keep condensation at bay?
cleaning my case... omgwtf Off Topic 17 November 25, 2007 02:26 PM
