Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 2, 2010, 10:04 AM
LaughingCrow's Avatar
Default OK I built it, now what?
I've searched through the various forums looking for the procedures that you should go through after you've put a system together. While I found a lot of useful information in bits and pieces, troubleshooting guides, etc, I haven't seen a guide that outlines the next stages.
I've seen where several people have suggested doing the memory test right after you've gone through the first POST (and that seems like good advice), but is there anything else to be done or could be done at this stage, before you install the O/S?
Once you've got the O/S installed and the motherboard drivers, what would be the next logical/practical things to do or test out?
i.e. what do you do when you've finished building it?
Thanks
Old March 2, 2010, 10:05 AM
MarkOne's Avatar
Thanks
I enjoy it for few minutes and I plan the next build
Old March 2, 2010, 10:19 AM
gingerbee's Avatar
rofl it's so true i thought i was bad
Old March 2, 2010, 10:37 AM
SugarJ's Avatar
Go here to install a lot of the things you should put on a new PC. Single installer does multiple programs, unattended. It will save you a ton of time. Ninite Easy PC Setup - Download/Install Multiple Programs At Once
Old March 2, 2010, 11:17 AM
Certainly, fill it with software.
But for those who build a lot of units, what is your process before loading in a ton of software, extra peripherals - - what should I be testing? Do I test the CPU, the video card (and how)?; do I tweak Windows, etc.
I've read about the test programs and monitoring programs mention on this site and I've ran them for temperatures and fans and CPUs, etc. I've seen varying opinions on burning a system in, etc. but I've yet to find a comprehensive plan or procedure to go from first POST to ensure you've built a stable system? I'm writing this on a newly built system, so I know it works, but is it working well? I've had a few crashes, figured out a couple of them.
I'm looking for ways to improve what I've done or ideas on what I may have missed and should have done, etc. (I've got another system to build and I learned a lot from this one.)
Thanks
Old March 2, 2010, 12:21 PM
MarkOne's Avatar
Thanks
I test the board on the bench if it post, and after I put all the part in the case and install the OS.. voila
when you start to worry to much and run all the bench and diag software available...problem apear.
Old March 2, 2010, 01:02 PM
gingerbee's Avatar
oh i just run it under load with prime95 for 12 to 24 hours to make sure it's all good. then i give it up to the client
Old March 2, 2010, 02:56 PM
Full Speed's Avatar
That is AWESOME. That's going to save me so much time. And I set up a lot of new PCs. Thank you.
Old March 4, 2010, 03:29 AM
norfolk's Avatar
Yeh Sugar, thx man That is one sweet program.I will try next install.
Old March 8, 2010, 01:33 PM
artistpavel's Avatar
Grab Acronis True Image or something like that and make an image of your tuned OS, so you don't have to reinstall it from scratch every time you mess things up.
Scratch built Ken_C Cases 6 July 19, 2009 06:39 PM
Need help with my custom built PC icepizza CPU's and Motherboards 1 June 29, 2009 01:19 PM
Scratch built Ken_C Case Mods, Worklog & Gallery 5 June 27, 2009 12:02 PM
AMD new built Chris New Builds 45 April 25, 2009 08:26 AM
1000$ New built jspot69 New Builds 123 March 19, 2009 06:20 AM
