Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old January 1, 2010, 06:17 PM
feerof's Avatar
Default How do I paint this case without losing the brushed finish?
Well, I've read a few case painting guides, however most of them achieve the high glossy look... which is not what I want. I just purchased a Coolermaster Stacker stc-101 from a friend of mine for 40 bucks... and this is going to be the first case that I have ever bought myself. However I do not like the colour silver... it doesn't feel... right...
The outer shell of the case is aluminum with a brushed finish. I want to keep the brushed look, but I don't want the silver look. Do you guys have any idea how to get by this? I think adding primer would fill in these gaps... which isn't what I want, however I've heard that the paint doesn't stick well onto metal because of how paint dries up, thus we add primer...
I want this to be a DIY project.
What do you guys think? Could I just paint it black and see what happens?
Here are some pictures:
Excuse the poor white balance choice my camera automatically picked =P
Had to clean the case a bit
Why have a case and not put food on it? =P
=o pokemon spotted!
Thanks guys!
Old January 1, 2010, 07:00 PM
Perineum's Avatar
I wouldn't touch it. I think paint isn't going to come out looking right. Perhaps this? Anodizing - Wikipedia, the free encyclopedia
Old January 1, 2010, 08:01 PM
feerof's Avatar
Why isn't the paint going to come out looking right?
And i don't think i have any time or money or patience to anodize a big sheet of aluminum =P, but that's a cool project though.
Old January 1, 2010, 08:35 PM
MarkOne's Avatar
you can't paint and have a brush effect , you have to clean, electrolyze, stain it and after boil the parts to seal the pores. you may have an other solution ; I will test it tomorrow on the left over of the hole I do today in a similar case.
Old January 1, 2010, 08:39 PM
Perineum's Avatar
I'm very interested to hear it....
Old January 1, 2010, 08:44 PM
MarkOne's Avatar
if this chemical work , it will not give a glossy finish .
Old January 1, 2010, 08:51 PM
Perineum's Avatar
Wonder if gun "bluing" chemical would work okay?
Old January 1, 2010, 09:50 PM
Sushi Warrior's Avatar
You would need to use oven cleaner then anodize it. A. Spraypaint (or any other paint) will fill the cracks and B. Once coated (sealed, w/e) its basically a smooth finish anyways. No matter how fine the paint, with that protective layer on it will never, ever work (and it won't work without it anyways).
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old January 4, 2010, 04:35 PM
feerof's Avatar
nvm, i decided to just paint over it... the case looks much better than compared to before =P
I didn't add primer, ... i know i know, you're suppose to... but i didn't sand down my case ... sooooo i didn't see the point...
What does primer do anyways?
i'll post pictures up later
Old January 4, 2010, 05:43 PM
jcmaz's Avatar
Primer makes sure that the paint sticks on to the metal. You should use primer before you paint your case or the paint will peel off.
-Plato
Painting my case: how do I stop paint from scratching off? quikgp Guides & How-to's 62 October 15, 2009 06:24 PM
Rig #1! Case Mod/Paint + Build chouchou Case Mods, Worklog & Gallery 37 December 15, 2008 09:05 PM
[WTB] Need some things to finish it off. chouchou Buy/Sell & Trade 7 December 4, 2008 09:24 AM
New case - need paint! encorp Cases 14 May 1, 2008 12:10 PM
Question about Case Paint. Supergrover Cases 5 June 15, 2007 06:02 PM
