Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old November 11, 2009, 03:21 PM
Mnpctech's Avatar
Default Installing 250mm cooling fan in your case
Here is my guide on installing a Thermaltake 250mm cooling fan in your side panel. The case I'm using for this guide is a Lian Li PC-7plus B midtower
Thermaltake 250mm cooling fan from performance-pcs, here
Thermaltake 250mm Silent Case Fan Products Model: TT250FAN [TT250FAN] : Performance-PCs.com, ... sleeve it and they will come
Fan Dimension 250 x 250 x 30 mm
Rated Voltage DC 12V
Fan Speed 600RPM ±10%
Airflow 67.69CFM
Noise 15 dBA
4 Pin Molex connector
List of Tools Needed
Power drill
1/4" drill bit
Jigsaw with 18 TPI cutting blade
Dremel or Rotary Tool with 1.5" cutting wheel
Measuring Square or Ruler
Pencil or Pen
3M brand Green Painter's Masking Tape
Center Punch
Phillips Screwdriver
Rounded Hand File
Medium grit sandpaper
"SEM brand Self Etching" Primer
"Plastikote brand Black Enamel paint
List of Supplies Needed
1x 1' x 1' sheets of Honeycomb Modders Mesh
4x #10 x 5/8 self tapping fan screws
4x fan silencing grommets
1x 6ft U-channel (cut down to 27")
Finding placement of the 250mm cooling fan in left side panel. We've positioned the fan 4" from the rear edge and 7" from the bottom edge of the panel.
Trace the outline fan with pencil onto the panel after applying 3M brand Green masking tape.
The masking tape also prevents scratches while cutting the fan hole.
Here is traced outline of Thermaltake 250mm cooling fan. Mark fan mounting holes
Using center punch to mark 1/4" drill holes for fan silencing grommets
Using 1/4" size drill bit to drill holes for fan silencing grommets.
Before we can using Jigsaw to cut the 250mm fan hole, we first make an incision for the Jigsaw blade with Rotary tool using 1.5" cutting wheel
We're using this styrofoam cushion to prop the panel so we have clearance below for using the Jigsaw.
Cutting 250mm fan hole with Jigsaw (use 18 TPI cutting blade)
A sheet of Honeycomb Modders Mesh will provide excellent ventilation
Cut down to 10" x 10" panel to serve as a grill for 250mm fan.
Let's paint the Modders Mesh Black to match our color scheme. First scuff the surface of the mesh with medium grit sandpaper to promote adhesion for the "self etching" primer base coat
After applying SEM brand "self etching" primer, we apply 3 coast of Plasti-kote Black enamel paint
4x Fan silencing grommets ready for installation
fyi: You can use a micro flat head screw driver to help gently pry the grommet into 1/4" hole
Finishing the edge of the 250mm fan hole with U-channel molding cut to 27.5" length
Our 250mm fan hole is finished and ready for installation of the fan!
We prefer to use #10 x 5/8" self tapping screws, these are Black Oxide
First lay down the Modders Mesh sheet (after the Black enamel paint has cured!
You will have to remove a small portion of the mesh around the mounting holes accommodate the #10 x 5/8" screws
The 250mm fan mounts as an Exhaust. It pulls warm air out from inside your computer case.
Now you have a cooler running system with less fan noise than smaller fans!
Old November 11, 2009, 03:31 PM
MarkOne's Avatar
Very nice and well documented
Old January 28, 2010, 08:46 AM
Sui's Avatar
Sui Sui is offline
Thx OP for the detailed steps on your job... I am impressed with your guide.
Question for everyone tho... any chance U-channel molding can be purchase in-store Toronto?
Hi there... I am new to HWC! Feedback:
Heatware | RFD | HoFo
Old January 28, 2010, 03:35 PM
I've searched high and low and haven't been able to find any. Perhaps a sticky with links to popular stores that sell modding supplies such as hard to find fans, lighting, U-channel, sleeving and what not.
Old January 29, 2010, 03:55 PM
Great guide thanks!
Only one question, if you put a 250mm fan as inlet, doesn't it need the same as outel in term of air pressure/flow thing?
Old January 29, 2010, 04:00 PM
gingerbee's Avatar
Good looking thanks
PC Case Mods Store
Old April 12, 2011, 12:41 PM
Mnpctech's Avatar
Originally Posted by Charloz24 View Post
Great guide thanks!
It would add Positive pressure, which pushes the warm out and helps keep your case free of dust.
Old April 23, 2011, 07:53 AM
Me0Mi0's Avatar
gee ... this is all I need ... more ideas!!
Old April 23, 2011, 10:48 PM
Nice mod! Too bad my side panel has a huge window XD.
Old May 30, 2011, 06:38 PM
Mnpctech's Avatar
You can cut the opening in windows too
250mm fans in Canada mchutch Computer & Electronics Hot Deals 1 August 23, 2009 08:37 AM
Quieter NB cooling (replace noisy 40mm fan) frontier204 Air Cooling 13 March 3, 2009 05:09 PM
[WTB] Acer Extensa 5620 cooling fan mchutch Buy/Sell & Trade 3 November 22, 2008 09:57 AM
Case fan speed!! Jarod_g29 Air Cooling 2 March 9, 2008 07:11 PM
Cooling question (fan and heatsink) Mr. Cipher Water Cooling 1 November 6, 2007 09:26 AM
