-   Guides & How-to's (http://www.hardwarecanucks.com/forum/guides-how-tos/)
-   -   Painting MX518 Logitech Mouse with "Carbon Fiber" Effect (http://www.hardwarecanucks.com/forum/guides-how-tos/25291-painting-mx518-logitech-mouse-carbon-fiber-effect.html)
Mnpctech November 7, 2009 05:31 PM
Heres the steps taken to dismantle the Logitech MX518 Gaming Mouse. We're painting it with a Carbon Fiber effect
http://www.mnpctech.3dpixelnet.com/p...semodblog1.jpg
You will find 3, marked cross patterns for screw locations, using blade
http://www.mnpctech.3dpixelnet.com/p...semodblog3.jpg
http://www.mnpctech.3dpixelnet.com/p...semodblog4.jpg
Once opened, these 6 screws must be removed. 3 fasten in the switch for the right hand buttons
http://www.mnpctech.3dpixelnet.com/p...semodblog5.jpg
After removing right side button switch, 3 more screws are located beneath and must be removed
http://www.mnpctech.3dpixelnet.com/p...emodblog5a.jpg
Before you can remove the MX518 mouse cover, you may have to push up the left/right mouse buttons up to clear the mouse body.
Then, gently, pull the cover off towards the rear of the mouse.
http://www.mnpctech.3dpixelnet.com/p...semodblog6.jpg
Apply masking alongside the MX518 Logitech emblem before prying off emblem with small flat head screwdriver.
http://www.mnpctech.3dpixelnet.com/p...semodblog7.jpg
To fill in the emblem hole, I'm using Evercoat, Metalworks, Polyester Glazing Putty with Blue Cream Hardener (not pictured)
http://www.mnpctech.3dpixelnet.com/p...semodblog9.jpg
Filling emblem hole of MX518. After mixing 1/4" size drop of Evercoat with dab of Blue Cream Hardener (not pictured)
http://www.mnpctech.3dpixelnet.com/p...semodblog8.jpg
If you apply too much filler, use paper towel to wipe off excess filler.
http://www.mnpctech.3dpixelnet.com/p...emodblog9a.jpg
Allow filler to cure for 60 mins before sanding w/ 400 grit sandpaper
http://www.mnpctech.3dpixelnet.com/p...emodblog9b.jpg
BEFORE PAINTING: USE THE PROPER SAFETY PRECAUTIONS
1. Wear Filtered Respirator Mask, Approved For Applying Automotive Aerosols
2. Work in Well Ventilated Area
5 coats of Rustoleum Sandable Primer (or until surface is filled)... allow to cure for at least 2 hours
http://www.mnpctech.3dpixelnet.com/p...emodblog9c.jpg
Scuff the final coat sandable primer with 400 grit sandpaper before applying base color coat
http://www.mnpctech.3dpixelnet.com/p...emodblog9d.jpg
NOTE! You can bypass needing a HVLP spray gun like ours, and apply "Aerosol" or Rattle Can Paint to your Mouse instead
The base color coat will be ISUZU factory color "Pewter" by PPG
http://www.mnpctech.3dpixelnet.com/p...emodblog9e.jpg
http://www.mnpctech.3dpixelnet.com/p...emodblog9f.jpg
http://www.mnpctech.3dpixelnet.com/p...emodblog9g.jpg
Gloss Black painted applied over rubber mesh (tool box liner) creates carbon fiber weave pattern
http://www.mnpctech.3dpixelnet.com/p...emodblog9h.jpg
Light coats of Gloss Black will blend in the weave pattern
http://www.mnpctech.3dpixelnet.com/p...emodblog9j.jpg
PPG brand Polyurethane clearcoat applied for maximum durability and shine
http://www.mnpctech.3dpixelnet.com/p...emodblog9k.jpg
You can buff out the clear coat on the mouse, for that extra shine!
http://www.mnpctech.3dpixelnet.com/p...emodblog9l.jpg
http://www.mnpctech.3dpixelnet.com/p...emodblog9m.jpg
http://www.mnpctech.3dpixelnet.com/p...emodblog9n.jpg
http://www.mnpctech.3dpixelnet.com/p...emodblog9o.jpg
Perineum November 7, 2009 05:46 PM
heh pretty cool man...
Surfer_2099 November 7, 2009 06:38 PM
So so useless...
... and yet so so beautiful! :clap: :thumb: :clap:
Cheers!
Loving_The_Paint_Effect_Canuck :)
Andy November 7, 2009 06:57 PM
Awesome work! Nice step by step as well.
gingerbee November 8, 2009 06:19 AM
someone once said something truly beautiful can't be truly useless ha ha
icarus2 November 8, 2009 10:51 PM
Holy crap, that is awesome!!
AmuseMe November 9, 2009 05:48 AM
Very nice! Could probably use this method for many more things.
miggs78 November 9, 2009 06:33 AM
^^ He probably wanna say to you Bill that "Amuse Me says: Bill you Amuse Me" :p..
Great work, you got me into thinking of doing mine now bill.. :D
Deviant November 9, 2009 06:48 AM
Very nice. Reminds me of Asus' rebranded MX518 with their gaming laptops:
http://www.notebookreview.com/assets/18891.jpg
silent1mezzo November 9, 2009 08:01 AM
Soo much nicer though because you don't have the ugly logos...
