Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old November 3, 2009, 09:47 PM
Default Lapped?
I have a guess on what it is.. but not completely sure. what does it mean when you lap a block? or a block is lapped?
Death to Apple
Old November 3, 2009, 09:53 PM
MacJunky's Avatar
It means: to google, then lick google because it is so yummy and good.
Old November 3, 2009, 10:00 PM
Kayen's Avatar
Sand down something .
To make it smooth. and sexy.
Kayen is stupid :D
Old November 3, 2009, 10:46 PM
Supergrover's Avatar
CPU Lapping - Google Search
I have lapped a few HS in my day easy as pie just dont press on the HS when your doing it.
R.I.P.
Old November 4, 2009, 12:33 AM
Thank you supergrover and Kayen. I thought that is what it was. I just wanted to double check and make sure. Diddnt want to start sanding down my blocks only to find out that lapping was something completely diffrent.
Death to Apple
Old November 8, 2009, 10:55 PM
IMHO, lapping a high end coolers will give very little improvements given that they are usually have a decent stock finish. Too much effort to too little gain.
Old November 8, 2009, 11:00 PM
When you go to a strip bar a dancer gives you a LAP DANCE. Then you've been LAPPED.....
"What is the colour when black is burnt ?" - Neil Young
Old November 9, 2009, 07:34 AM
gingerbee's Avatar
pointless .imho
Old November 9, 2009, 07:58 AM
biff's Avatar
High end coolers do usually have a good finish but that not always guaranteed. Check it by holding a razor to it and hold it up to a light to look for any light creeping under to check for flatness. The IHS on cpu's is another story, they can be pretty far from flat.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old November 9, 2009, 08:06 AM
CMetaphor's Avatar
+1. Its usually the CPU that needs lapping far more than the HSF.
Found a nice pic to demonstrate (google image search = win!):
See how the edges after step 3 (lower left pic) are still untouched after the lapping has already started? this means that the center of the CPU had a "high spot" as compared to the corners. Lapping will increase the contact area and reduce the amount of TIM you need between it and your HSF.
slightly OT: I like how this user drew an "X" on the HSF to be able to easily spot the high/low spots. Cool.
[WTT] e5200 lapped for your AM2/AM3 CMetaphor Buy/Sell & Trade 12 July 15, 2009 06:23 AM
Lapped my i7 Apollo4g CPU's and Motherboards 12 March 24, 2009 12:50 PM
Lapped my Q6600 and Vendetta 2 Dadi_oh Air Cooling 9 February 20, 2009 09:02 PM
FS: Cherry picked lapped E6850 ES Wankerfx Buy/Sell & Trade 3 May 16, 2008 01:05 PM
lapped e6600 enaberif Overclocking, Tweaking and Benchmarking 17 October 15, 2007 09:24 PM
