I'll try to present a mini-guide for RivaTuner.
Before I start I must say that is not the latest and greatest RivaTuner guide but original was for 2.09 RT version. Meantime some options has changed, but for having an idea about RivaTuner I think is still pretty good.
Some of pictures below are borrowed from
Derek's guide after I receive his permission (unfortunately his site is down so I decided to put my guide here instead) some are mine with my old 8800GT and some are from my actual GTX 260 so don't be confused about different pictures, final result matters.
Official page for RivaTuner.
After download and installation (on x64 systems don't forget to click yes on that update request at the end of install, that is RivaTuner signed driver) we see something like this
Every option has a build-in help (at least for early version of RivaTuner but how users don't bother to read them unfortunately
Unwinder drop that build-in help in latest builds). For Vista64 users download a
patch for this feature to be active.
For Win7 x64 user the patch is
here.
Fan profiles
In section
Driver settings click on the arrow next to "
Customize...". We'll see a menu with many options. For now we focus on video card icon. Click on it and we'll see a window
System tweaks. Here we can play with video driver settings.
Select
Fan tab
Then
direct control from drop down menu
We move the slider until our desired value of fan speed
Then click on
Apply button and we can save this entry as a fan profile.
Click on floppy icon to save profile
You'll be asked for a name for saving, give one suggestive and click
OK.
Same steps for multiple fan profiles. In my example I've made fan profiles for 80% and 100% fan speed.
Overclock/underclock profiles
We come back to
System settings icon
Click on "
Enable drive-level hardware overclocking" check box from
Overclocking tab
You'll be warned about a reboot for reading frequencies. Click
Detect now.
Select
performance 3D from drop down box.
Move slider at your desired value for GPU, shader and memories. WARNING, test your new frequencies for stability before apply (don't hunt me if you fry your card from first OC attempt).
Click
Apply.
Save profile with a click on floppy icon
Give profile a suggestive name.
Same for a underclock profile and a default one.
Give profiles suggestive names.
Now we'll add them in
Launcher tab. We give them a name, we assign a hotkey, we check
Associated overlocking profile box and select overclock profile. Click
OK.
After we finish to add all
Launcher profiles they'll look something like this
Add Launcher items
Select
Launcher tab
Click on that
+ to add a new item
Select "
Regular item" and click
OK
Give it a name.
Then link it with a fan profile
Rinse and repeat for others fan profiles.
Creating tasks (Task scheduler)
Those
Scheduler Tasks are an elegant mode to launch a
Launcher item or other applications when an event is triggered.
Select
Scheduler tab
Click on the same
+ for adding a new task.
Click on drop down menu to select Fan speed 100% element
Click
Run task drop down menu to select the event which triggers Fan speed 100%. In our case "
on hardware monitoring range event"
If you don't have active "
background hardware monitoring" you'll be warned to do so after task selection.
Click
Yes.
Choose from drop down menu under
Data source Core temperature. If you have 2 video cards then it will appear Core temperature 0 and Core temperature 1.
Now enter
Range min and
Range Max for launching this profile. Click
OK when you're ready.
Here you must enter 0 in those 2 boxes
Data sampling period and
Task freezing period.
Repeat for Fan speed 80%
And Fan speed 60%
Continue until you finish all your desired profiles
If you have a fan problem with changing his RPM between 60% si 80% profiles make a gap between temperatures for which profile is active. Something like 56-63°C and 68-75°C instead 56-65°C and 66-75°C
Aditional Tasks
We can define another tasks. For example system shutdown for a high GPU temperature (fan broken for example).
We add a new task, select
application from drop down box and click on
Browse to choose our option.
In our case at the end of list we select
System shutdown.
Select "
on hardware monitoring threshold event" task, select
core temperature as source and we set 89 value and "
upward" direction.
Now what? At 90°C core temperature system will shutdown.
Same you can define what profile to launch on RivaTuner startup overclock, underclock, or standard frequency.
Some examples
Hardware Monitoring.
A lot of monitoring option here. Most of then came already with RivaTuner but we can use third-party plugins (Core2Duo sau AMD core temperature, SpeedFan or Everest, RealTemp for example).
At first launch of
Hardware Monitoring you may be warned about activation of some plugins. Click
Yes if you want them enabled automatically or
No if you're brave and want to activate them by hand later.
Main window
Hardware Monitoring
Be sure that you activate
background monitoring (click on that red circle)
Now let's take a look on
Setup
Here we can select what we can monitor/control with RivaTuner and where we can see it(on screen, in tray or on your fancy G15 screen).
We begin with selecting
Core temperature then select
Setup
Those are all
Core temperature options. If you want to see temperature in tray or/and as tooltip, or OSD or on your G15 keyboard screen check those boxes.
Below is a screenshot with OSD informations provided by RivaTuner
We can change color for tray temperature.
Pick a color and
OK
You can define another range for showing temperatures.
When you're done click
OK.
The same drill for other monitoring options.
OK.
Below is what RivaTuner show me in tray: GPU and ambient temperature, distance to TJMax Core0 and Core1 (from RealTemp plugin), MB temperature and HDD's temperatures (via Everest plugin).
Using Statistics Server.
One of the strong points of RivaTuner. With RTSS we can control launching profiles (overclock, fan) when detects a 3D application launch (game or anything else 3D).
For that we need RTSS running in background. We can launch it from Start-Programs-RivaTuner group or we can make a
Launcher item with it.
RTSS starts minimized. Click on his icon to maximize it.
Here we have some cosmetics settings, start with Windows, show/hide OSD monitoring, screen coordinates, color of what you see in OSD.
HINT: Hover mouse over different settings, that contextual help is priceless.
Let's see how we can automate launching overclock/stock/underclock profiles linked with launching/exiting a game.
Open
Hardware Monitoring, click
Setup, search
Hardware acceleration and click on check box to activate it.
OK, now
Hardware acceleration will monitor our computer and when it will detect launching a 3D application it will have value 1 and when we close that 3D application will come back at 0 value.
Now we must add 2 tasks in
Scheduler tab which will launch my profiles stock and underclock based on
Hardware acceleration. One task is Stock, select item then Stock. Select "
on hardware monitoring threshold event", then we choose source
Hardware acceleration,
threshold value 0.5 direction
upward.
Click
OK.
Same we add a underclock task, but on direction we choose
downward.
Now what's happens when we launch a 3D application?
Hardware aceleration change in 1 and Stock profile is launched. Leaving 3D application
Hardware acceleration come back to 0 and underclock profile is launched.
This kind of profiles management works wonderful but only with 2 profiles. What if we have a game which need more power from our GPU and we need our overclock profile in action?
We can do that, of course: we define an item for that game in
Launcher tab and we associate it with our overclock profile and a keyboard shortcut.
Everything is easy now, when pressing our keyboard shortcut for launching the game, RTSS detects changing of
Hardware acceleration value and launch the profile assigned for that game.
ADDENDUM
Another method for controlling fan speeds based on low-level settings. It works only on ADT7473 controller.
Open RivaTuner, then
Power user tab (answer
Yes at that question) and we seek RivaTuner \ Fan. Double-click
AutoFanSpeedControl and insert 3 for having access at parameters from
Low-level settings (be sure that button marked with a red square is pressed in Dec value otherwise we need to enter a Hex value). Click Apply, then OK for saving and closing.
We launch again RivaTuner, press
Customize... then first left button
Low-level system settings.
In the new window we check
Enable low-level fan control and be sure to set on Auto.
Now we are interested in values from that box with a scrollbar. Those are:
# Duty cycle min: minimum fan speed in %
# Duty cycle max: maximum fan speed in %
# T min: Temperature minimum limit. If temperature is below that value fan speed will remain at value defined in
Duty cycle min
# T max: It doesn't show here but is GPU temperature for fan running at 100%. This is calculated by us based on T range below.
# T range: It's a calculated value based on others parameters and it establish how fast or how slow fan RPM's grows with GPU temperature.
# T operating, T low, T high: Those values affects dynamic
T min control and we don't want this so we put some bogus values (150, 0, 150 degrees).
Formula for T range (found it somewhere on guru3D):
T range = (2/3) * (Tmax - Tmin) / [(Dc max - Dc min)/100]
Keep in mind that T range which I follow is that value highlighted in picture below. GPU temperature reported by nVidia driver has 8°C offset.
And valid numbers for T range are 5, 8, 10, 13, 16, 20, 26, 32, 40, 54, 80. Other values are rounded at one of these.
My example:
I want 27% fan speed until 48°C (56°C reported by nVidia driver) then a liniar growing until 100% fan speed for T max 90°C.
Duty cycle min = 27
Duty cycle max = 100
T min = 48
T operating = 150
T low = 0
T high = 150
T max = 90
So T range = 2/3*42/0.73 = 38.35. Rounded 40.
OK, now let's see what I get after entering those values, check box with Apply settings on Windows startup and Save.
A pretty nice curve without fan bumping up and down at changing fan profiles and without overwriting my VGA BIOS with new values.
That's all folks, I know it's not a very in deep guide but basic tasks like fan and overclock profiles, hardware monitoring and OSD display are covered.
Hope it helps somebody, someday, somewhere. :)
PS. Bear with my English mistakes and if is something awful wrong I'll ask a Mod to correct my novel. Thanks.
