-   Guides & How-to's (http://www.hardwarecanucks.com/forum/guides-how-tos/)
-   -   Mnpctech's Guide to Tools For Case Modding. (http://www.hardwarecanucks.com/forum/guides-how-tos/25027-mnpctechs-guide-tools-case-modding.html)
Mnpctech October 31, 2009 03:52 AM
A lot of people ask me about the Tools and methods I use for Case Modding.
Some of the Tools are unique, I've included examples of how they're used :thumb:
THINK SAFETY FIRST!
Safety Glasses
http://www.mnpctech.3dpixelnet.com/i...ics/UVEXwb.jpg
Respirator Mask with canister filters
Use when sanding, painting or using any hazardous chemicals
http://www.mnpctech.3dpixelnet.com/p...ry/GvLwin2.jpg
Rotary Cutting Tool
The most versatile tool for case modding. You can cut plastics, metals, grind and polish. Dremel brand is most popular. Black & Decker and Craftsman versions are also popular.
http://www.mnpctech.3dpixelnet.com/i...ics/Dremel.jpg
http://www.mnpctech.3dpixelnet.com/i...cs/Dremel2.jpg
Dremel Techniques For Case Modding, Part 1
[youtube]9iMiH8wYTDY[/youtube]
Dremel Techniques For Case Modding, Part 2
[youtube]gTDpxmGEC58&feature=related[/youtube]
I hear a lot of complaints about cutting discs breaking when cutting metal. You need to use aluminum reinforced discs like these Reinforced Dremel Cutting Discs
Reinforced 1.5" Dremel Cutting Discs. Available here
http://www.mnpctech.com/bolt2.jpg
Cordless Power drill
Minimum volts recommened 14.4V) with bit sizes 1/16 through for cutting various mounting holes and
operating hole saw attachments. DeWalt brand power tools.
http://www.mnpctech.3dpixelnet.com/p...dlessDrill.jpg
Hole saw attachments for Drill
For cutting fan holes in acrylic and metal.
80mm = 3 hole saw
92mm = 3.5 hole saw
120mm = 4.5 hole saw
http://www.mnpctech.3dpixelnet.com/p...MNholesaws.jpg
Guide To Using Hole Saw Attachments For PC Modding
[youtube]7wGlWZ24QsE[/youtube]
Greenlee Knock out Punches
Greenlee part # 730EBB-120 Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new.
http://www.mnpctech.3dpixelnet.com/i...wing9dtool.jpg
Threaded shaft of Knock-out punch
http://www.mnpctech.3dpixelnet.com/i...entSwing9g.jpg
Knock-out punch blade
http://www.mnpctech.3dpixelnet.com/i...entSwing9h.jpg
Ready to cut hole.
http://www.mnpctech.3dpixelnet.com/i...entSwing9i.jpg
You need leverage. Using 19" Socket wrench to draw in knock-out punch balde
http://www.mnpctech.3dpixelnet.com/i...entSwing9j.jpg
Clean Cut
http://www.mnpctech.3dpixelnet.com/p...brary/GvL5.jpg
Video with Bill Owen using Greenlee Knock Out Punch
[youtube]NX3YbhRrOvM[/youtube]
Roper Whitney No. 5 Jr Hand Punch kit available here
Hand punch (estimate $60 new)
http://www.mnpctech.3dpixelnet.com/i...wing9etool.jpg
(for cutting fan mounting holes or enlarging existing fan mounting holes for rubber silencing grommets)
http://www.mnpctech.3dpixelnet.com/p...brary/GvL3.jpg
Hand Punch makes clean fan screw holes. No deburring.
http://www.mnpctech.3dpixelnet.com/p...brary/GvL4.jpg
Jigsaw
Used for cutting panels and acrylic sheets. (minimum 18 teeth metal cutting blade) Black & Decker brand Jigsaws available here
http://www.mnpctech.3dpixelnet.com/p...ry/GvLwin7.jpg
Hand files
Deburring jagged edges on both plastic and metal.
http://www.mnpctech.3dpixelnet.com/p...ry/GvLwin8.jpg
Mouse Sander
Sanding body filler. Prep case panels for paint.
http://www.mnpctech.com/case.mod.paint.2.gif
12 and 24" Combination Square Rulers
Aligning windows, fan holes etc
http://www.mnpctech.3dpixelnet.com/p...brary/GvL1.jpg
Scotch #4010, Super strength adhesion clear mounting tape. Used for mounting windows in computer cases.
3M Scotch 4010 Mounting Tape Case Mod Tape of the Gods
http://www.mnpctech.com/4010scotch3m...pctech.com.jpg
[youtube]4ktMsp2dFIM&feature=channel_page[/youtube]
Pop Rivet Gun
Most chassis accept 1/8 size rivets.
http://www.mnpctech.3dpixelnet.com/i...opRivetGun.jpg
Most Computer Chassis will accept 1/8 diameter Pop rivets, Gripe range .092" - .125" for Computers.
Pop Rivets For Computer Cases
http://www.mnpctech.com/pop_rivet_bl...sis_doomed.jpg
http://www.mnpctech.com/pop_rivet_bl...se_chassis.jpg
Metal Nibbler
Cutting case panels
http://www.mnpctech.3dpixelnet.com/i...ModNibbler.jpg
Metal Tin snips
Cutting Modders Mesh & Sheet metal
http://www.mnpctech.3dpixelnet.com/i...entSwing9f.jpg
Solder Gun or Pencil
http://www.mnpctech.3dpixelnet.com/i.../SolderGun.jpg
Heat Gun
Heat shrink tubing, bending acrylics/plastics
http://www.mnpctech.3dpixelnet.com/i...cs/HeatGun.jpg
3M Scotch 233+ Green tape
I was told about this tape at local auto parts and Automotive paint supplier, "Red Rooster" which is now AutoMate. I had to cut a window in a Lian Li full tower, and wanted a masking tape with really strong adhesion, but didn't leave glue-like residue. It's been used in majority of my own projects and modding guides since*
https://mnpctech.com/images/companie...oll_carton.jpg
https://mnpctech.com/images/companie..._roll_ebay.jpg
More Tools, but no photos yet..
Phillips Screw drivers(variety of sizes)
Wire Stripper & Cutter
Butane Torch(for use with heat shrink tubing)
Tape Measure
Bench Vise
gingerbee October 31, 2009 05:17 AM
cool thank never seen that punch before kinda pricey but wow
Pelt October 31, 2009 06:25 AM
The number of experts on this forums just amazes me. We've got, water cooling gurus, component geniuses, oc clocking speed demons and now case modding artists!
Thanks for this great list of tools really helpful should I ever consider modding my case. I also checked out you website and the links provided great stuff Mnptech keep it up.
Surfer_2099 October 31, 2009 10:11 AM
Cheers for MNPCTECH wikis!
Dremel_Canuck :)
ayah October 31, 2009 12:59 PM
That knock out punch blade thing is really neat, never seen one before. Thanks for the guide!
sa seba October 31, 2009 02:41 PM
Next up, a tutorial on how to properly paint a case and what to use for it?
pretty please ;-)
miggs78 October 31, 2009 03:22 PM
Wow.. Bill.. Gr8 stuff compiling this for us.. Very useful..
gingerbee October 31, 2009 07:54 PM
pretty please ;-)
you could check out there site painting cases is there :thumb:
Mnpctech November 4, 2009 05:45 PM
Glad you guys like it :biggrin:
Theres a wealth of paint guides on Google :thumb:
computer painting guide - Google Search
dragoonxx November 10, 2009 01:21 PM
I think I had seen a deburring tool on your website for one of your hole guides, where did you get that?
