Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #81 (permalink)
Old May 21, 2011, 05:39 AM
Mnpctech's Avatar
If you're using 1/2" Hole saw Arbor, your Drill size must be 1/2"
Quoted from Amazon Product Description
It can be used in 1/2 inch capacity drills and larger. The arbor has a 5/8-18 thread and can be used on hole saws from 1-1/4 inch and larger.
  #82 (permalink)
Old May 21, 2011, 03:25 PM
Mnpctech's Avatar
A Micrometer is widely used for precise measurement of small distances. I use a Micrometer to measure the thickness in materials like sheet metal or aluminum. You can also use a Micrometer to measure the diameter of a cylindrical shape or sphere.
Types of Micrometers:
Outside micrometer
(aka micrometer caliper), typically used to measure wires, spheres, shafts and blocks
Inside micrometer
, used to measure the diameter of holes
Depth micrometer
, measures depths of slots and steps.
This is a Starret T436XRL-9 Outside Micrometer from Amazon
This is a Metric "Caliper" style micrometer made by “Draper.” It’s manufactured from hardened stainless steel. Slider displacements are amplified by a rack and pinion mechanism and indicated on the dial. Four way measurement: internal, external, depth and step. Reading 0.02mm. Slider has lockscrew function. Display packed in plastic storage case.
  #83 (permalink)
Old May 28, 2011, 05:06 AM
Mnpctech's Avatar
Greenlee part # 730EBB-120 Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new.
YouTube - ‪Mod Men Show Offcuts: "PC Case Mods with a Knockout Punch!"‬‏
  #84 (permalink)
Old June 7, 2011, 08:35 AM
Mnpctech's Avatar
Avoid fraying your PSU cable sleeving ends by using a Heat Cutter for cable sleeving.
Read more information about TechFlex Sleeve Cutting Tools PDF
  #85 (permalink)
Old October 7, 2011, 09:24 PM
ZZLEE's Avatar
Default Sticky this Please
Please sticky this thread
It has some vary valuable info
Thanks ZZLEE
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #86 (permalink)
Old December 30, 2011, 07:30 AM
Mnpctech's Avatar
This would be nice to own. CNC Shark Pro Plus Router, sold for $3,599.99 by ROCKLER
You can use the CNC Shark for carving, cutting, engraving, and etching hard materials that include, aluminum, MDF, wood, pvc, plexiglass, acrylic, and plastic.
You must supply a PC computer with USB 2.0 port and a Bosch Colt router (router sold separately). Simply connect the USB cable to the controller box and the other end to your computer (not compatible with Mac computers). The CNC Shark work table measures 28-1/2” wide by 36” long. The router itself can be moved over a 25” x 25” work path centered on the table. With its open end design work pieces longer than 36” can be placed into the machine, and continuous machining is possible with careful indexing of the workpiece. The table is much improved over the original Shark and Shark Pro in that its made of a blue anodized extruded aluminum channel which allows for great flexibility in clamping down workpieces. CNC Shark does include Vectrix CAM and 3D design software, but you'll want better graphics package like CorelDraw or Adobe Illustrator to create advanced artwork.
  #87 (permalink)
Old December 29, 2012, 10:02 AM
Bad213Boy's Avatar
Trial Member
I don't know if this thread is still active, but I was checking out Gups Stargate Pyramid Case Mod and saw that he used a CD/DVD Drive to open and close a panel. I can't figure out how the panel actually pushes out first and then rises. Plus, where can you get mechanical mechanisms like this for models so that we can use them for case modding?
  #88 (permalink)
Old February 6, 2013, 06:26 AM
neveer even thought about punches, thats a dam good idea :P
Bought Items:
GTX 470 from ZeroFlux
Swiftech MCW60 from chubaka
Sold Items:
Steelseries Siberia V2 to MAK
Zalman Fan Controller, OCZ Mem Fan Funguseater
Current system:
i5 2500k @ 5 Ghz
Zotac gtx 470
8GB Corsair Dominator ram @ 1333
  #89 (permalink)
Old February 17, 2013, 05:35 AM
Mnpctech's Avatar
Very clever idea, Thank you for sharing it!
Antec 300 modding or new case Bomberman07 Cases 21 April 4, 2009 05:25 PM
Dremel for Case modding serenity Cases 13 March 30, 2009 05:44 PM
Info in Modding a case? chouchou Guides & How-to's 7 November 3, 2008 07:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 07:23 PM
