Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #71 (permalink)
Old May 5, 2011, 11:48 AM
lowfat's Avatar
If you cut an entire window w/ that nibbler your hands are going to be sore you won't be able to use them for days. I highly suggest the higher quality nibbler they sell. Bessey D23-BE Super Nibbler Tool Products Model: D23-BE [D23-BE] : Performance-PCs.com, ... sleeve it and they will come
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #72 (permalink)
Old May 6, 2011, 05:25 AM
Mnpctech's Avatar
Great suggestion lowfat!
For custom wiring, you'll need a Soldering Gun or Wand
The ideal set up is this 40 watt "Soldering Station" by Weller (WLC100) $56.99 on Newegg
It hold your wand, for safety sake! You can adjust the Wattage. You can clean it on the included sponge, which
rids the tip of oxidation that builds up on its surface, which accumulates rather rapidly and becomes a corrosive agent that will eventually eat away at the tip and ruin it.
This WELLER 8200 is the type of Solder Gun I grew up with... A built-in light to illuminate your work, and heats up very quick with 100 - 140-Watts of heat.
This Blazer SI-100 Excalibur Multi purpose Butane Solder Wand / Torch Kit is great for mobility and has several different attachments for a variety of tasks. You can also reach tight spaces and be used for heat shrinking cooling fan wires and custom sleeved PSU cables. The only downside is you have to periodically refuel it with Butane Listed on Amazon
  #73 (permalink)
Old May 6, 2011, 05:38 PM
Mnpctech's Avatar
A good SAE/Metric Hand Tap & Die Set will allow you to thread and repair stripped screw holes. For PC Modding & Repairs, I suggest purchasing a set that has tap sizes for 6/32 and 4/40 screws.
60 piece set for $39.99 on Harbor Freight
  #74 (permalink)
Old May 6, 2011, 10:48 PM
Supergrover's Avatar
Having cut and installed a few windows in my day I have to say a jig saw is the only way to go. But yeah I would take that nibbler over the first one.
R.I.P.
  #75 (permalink)
Old May 8, 2011, 05:02 PM
lowfat's Avatar
Had to pay out of the a** for one of these locally. However I've had to re tap every single XSPC radiator I've purchased, so it is likely worth it.
Queen of Dreams WIP
Big Lian Li
Complete
  #76 (permalink)
Old May 8, 2011, 09:18 PM
dragoonxx's Avatar
I bought myself a set of mastercraft ones (probably nowhere near the quality as above mentioned) but canadian tire puts the set on fairly frequently...however, I have yet to be able to find a 6-32 NF tap or die
  #77 (permalink)
Old May 9, 2011, 11:36 AM
Mnpctech's Avatar
I've had to re tap Black Ice Radiators
  #78 (permalink)
Old May 12, 2011, 12:58 PM
Sorry for bringing back an old post but I thought my question would be best here.
Would this work for cutting acrylic/plexi?
Klein Tools - Quick Cutter Adjustable Hole Saw - 53731SEN - Home Depot Canada
i want to make a 140mm hole in a 0.80 piece of plexi.
SOLD:
Tritton AX Pro (mchutch)
Logitech Harmony 520 (Phill)
  #79 (permalink)
Old May 14, 2011, 05:24 AM
Mnpctech's Avatar
Yes.
You can also use a 5.5" size Hole Saw Attachment for installing 140mm fans (140mm = 5.51181")
Amazon has good selections for 5.5" "Bi-Metal" Hole Saw attachment for your Power drill, HERE
In order to use the Hole saw, you'll need an Arbor that fits your Powder Drill or Drill Press. Mine is 1/2"
Amazon.com: Lenox Tools 300033L Solid Shank Arbor for Hole Saw: Home Improvement
  #80 (permalink)
Old May 14, 2011, 10:58 AM
Thanks for the reply. I noticed the link you included at Modmenshow.com. but the problem is not all items will ship North.
Will any arbor fit any hole saw?
Im able to get this arbor
Amazon.com: Milwaukee 49-56-7140 7/16-Inch Quick Change Hole Saw Arbor: Home Improvement
and this Dewalt Hole saw.
Amazon.com: DEWALT D180088 5 1/2-Inch Hole Saw: Home Improvement
Im sure they will work together, but would appreciate the OK before placing an order.
NM. Shipping will cost me $35 on top of the tools... Im just going to go with this.
Mastercraft Circle Hole Cutter | Canadian Tire
SOLD:
Antec 300 modding or new case Bomberman07 Cases 23 February 21, 2016 05:26 PM
Dremel for Case modding serenity Cases 13 March 30, 2009 05:44 PM
Info in Modding a case? chouchou Guides & How-to's 7 November 3, 2008 08:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 07:23 PM
