Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #41 (permalink)
Old July 14, 2010, 03:25 PM
Mnpctech's Avatar
In order to use the Hole saw, you'll need an Arbor that fits your Powder Drill or Drill Press. Mine is 1/2"
Amazon.com: Lenox Tools 300033L Solid Shank Arbor for Hole Saw:…
  #42 (permalink)
Old July 14, 2010, 11:11 PM
Originally Posted by Mnpctech View Post
I've had this 12" Craftsman Bench top Drill Press for 4 years without any problems, other than the LED swivel light burned out. 5 speed (manual drive belt) with digital depth readout and Laser cross hairs. $219.00 at Sears
  • Item# 00921914000
  • Mfr. Model# 21914
Nice...
  #43 (permalink)
Old July 15, 2010, 03:26 AM
Mnpctech's Avatar
It's been very reliable. I've used the depth readout a few times for making counter sunk holes in acrylic.
  #44 (permalink)
Old July 15, 2010, 09:09 AM
Yeah, that's an interesting feature. I haven't seen a DRO on a drill press before (though I am used to using very old ones).
  #46 (permalink)
Old September 27, 2010, 09:55 AM
Mnpctech's Avatar
A Jigsaw should be in every Modder’s arsenal of tools. It’s the most efficient hand power tools for cutting a chassis or case panel. The $39.97 price tag on this Black and Decker JS660 prompted me to review it!
Black & Decker JS660 Orbital Jigsaw Review. | Case Mod Blog
  #47 (permalink)
Old November 4, 2010, 05:31 AM
Mnpctech's Avatar
I've updated the Fan / Radiator Printable Template for 140mm Fans! 140mm, 280mm, 420mm, 560mm Radiator & Grill (20mm spacing) printable templates
  #48 (permalink)
Old November 18, 2010, 01:06 PM
Mnpctech's Avatar
I use the Roper Whitney No. 5 Jr Hand Punch kit available here for making all of the fan mounting holes
  #49 (permalink)
Old November 20, 2010, 04:27 AM
Mnpctech's Avatar
Theres been a few case mod books that have been published over past several years, to accompany your workbench shelf
Yoshi's Mods
PC Mod Projects: Cool It! Light It! Morph It!
Build Your Own High-Performance Gamer's Mod PC
Going Mod
"Case Modding for Dummies" (I hear) is in the works
"PC Chop Shop: Tricked Out Guide to PC Modding" by David Groth. Check out the printable Chapter on Painting, ftp://ftp.sybex.com/4360/4360ch08.pdf
Maximum PC Guide to Extreme PC Mods
  #50 (permalink)
Old November 20, 2010, 08:44 AM
BrainEater's Avatar
There is already "PC modding for dummies" , and in fact , my submersion rig is one of the pics in that book.
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Antec 300 modding or new case Bomberman07 Cases 21 April 4, 2009 05:25 PM
Dremel for Case modding serenity Cases 13 March 30, 2009 05:44 PM
Info in Modding a case? chouchou Guides & How-to's 7 November 3, 2008 07:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 07:23 PM
