<~----> Mnpctech's Guide to Tools For Case Modding. - Page 4 - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #31 (permalink)
Old July 2, 2010, 01:45 PM
Mnpctech's Avatar
If you plan to add additional or larger cooling fans, these templates and video guide may come in handy!
Fan Template Download Page posted here
Computer Fan Hole Grill Templates 80, 90, 120, 140mm
Hole saw attachments for Drill
80mm = 3” hole saw
92mm = 3.5” hole saw
120mm = 4.5” hole saw
140mm = 5.5″ hole saws
  #32 (permalink)
Old July 2, 2010, 04:49 PM
Shadowmeph's Avatar
this is the first time I have seen this post allot of good stuff :)
  #33 (permalink)
Old July 4, 2010, 05:07 PM
Mnpctech's Avatar
Glad you found it helpful!
Please feel free to share any Tool recommendation of your own
  #34 (permalink)
Old July 13, 2010, 10:43 AM
Mnpctech's Avatar
Printable Template for Radiators with 140mm Fans! 140mm, 280mm, 420mm, 560mm Radiator & Grill (20mm spacing)
  #35 (permalink)
Old July 13, 2010, 11:08 AM
lowfat's Avatar
Has anyone found a place where you can buy a 120mm Greenlee Knock Out Punch (730EBB-120) in Canada?
Also pending the metal a possibility when using one of these? It seems like it would need a lot of torque.
  #36 (permalink)
Old July 13, 2010, 04:27 PM
Mnpctech's Avatar
You can find Greenlee Canadian Distrib on their website, WHERE TO BUY - Greenlee A Textron Company
I've used it on very thin aluminum cases and as long as you support the weight with your hands, you'll be Ok.
Speaking of big tools, I took some shots of My Grizzly G0580 14" Bandsaw 3/4 HP... I've owned it for 4 years without any problems. You can use 1/8" x .025 bi-metal blade for cutting acrylic and metal sheets. I usually cut 1/8" thick sheets.
Grizzly 13" Bandsaw in my workshop
Von Dutch pinstripes (not included with purchase)
Aluminum fence!
  #37 (permalink)
Old July 13, 2010, 04:44 PM
scruff's Avatar
any electrical wholesaler KMS tools etc
  #38 (permalink)
Old July 13, 2010, 05:33 PM
lowfat's Avatar
Swell. Even have a bunch locally. Hopefully they'll have one.
  #39 (permalink)
Old July 14, 2010, 04:56 AM
Mnpctech's Avatar
I would watch Ebay as well for Knock-out punches, I found 3” for 80mm fans and 3.5" blade for 92mm fans on Ebay.
I've had this 12" Craftsman Bench top Drill Press for 4 years without any problems, other than the LED swivel light burned out. 5 speed (manual drive belt) with digital depth readout and Laser cross hairs. $219.00 at Sears
  • Item# 00921914000
  • Mfr. Model# 21914
  #40 (permalink)
Old July 14, 2010, 09:57 AM
Mnpctech's Avatar
You can use a 5.5" size Hole Saw Attachment fir installing 140mm fans (140mm = 5.51181")
Amazon has good selections for 5.5" "Bi-Metal" Hole Saw attachment for your Power drill, HERE
Antec 300 modding or new case Bomberman07 Cases 21 April 4, 2009 05:25 PM
Dremel for Case modding serenity Cases 13 March 30, 2009 05:44 PM
Info in Modding a case? chouchou Guides & How-to's 7 November 3, 2008 07:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 07:23 PM
