Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old February 27, 2010, 04:19 AM
Mnpctech's Avatar
I did a box opening of Black & Decker's RTX Rotary Tool. It's an affordable alternative to Dremel, and it fits Dremel attachments
YouTube - Black & Decker RTX 3 Speed Rotary Tool Box Opening
  #22 (permalink)
Old March 27, 2010, 03:04 PM
Mnpctech's Avatar
My latest addition to the modding arsenal. Craftsman 8" bench top sander. I've been using the disc sander primarily, esp on acrylic and aluminum pieces.
http://www.craftsman.com/shc/s/p_101...rd=belt+sander
  #23 (permalink)
Old March 27, 2010, 03:36 PM
ZZLEE's Avatar
Default Shapening
those gaggets are the best fore shapening tools with the a different grit of sanpaper also.
Nice goide thanks
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #24 (permalink)
Old March 27, 2010, 04:33 PM
HaDeS
Guest
Posts: n/a
oh thats nice... i could use that on some of my tiling jobs heh.
  #25 (permalink)
Old March 29, 2010, 11:22 AM
The el cheapo method to slicing and dicing cases
the simple way to cut circular holes in many types of materials. The 678-01 Circle Cutter & Straight Edge Guide attaches easily to the Dremel High-Speed Rotary Tool and cuts perfect circles from 3/4" to 12" in diameter
- or -
Dremel router attachment
Includes
* Plunge router attachment
* Edge guide
* Circle cutting guide
* Mounting wrench
* Instructions
...those above plus a SET of carbide hobby bits from Princess Auto and you can go blow hole crazy.
  #26 (permalink)
Old March 30, 2010, 02:57 PM
Trial Member
Cool. Dealextreme has some scary looking "hole cutter" too. It might work for aluminum but I don't think I'm going to try and find out. My 1100 series dremel is not compatible with their accessories like those above, but I have some reinforced cutting discs so I could do things the hard way I suppose. Those videos make it look easy enough, so thanks for those. I have a Lian Li so at least I can buy a replacement top or side panel if I screw things up horribly :)
McMaster won't ship to Canada anymore btw.
Anyways I'll update this post later with some more tools, there's a lot of specialized stuff I use for working on the PC.
1) Since PCs use philips screws for just about everything, I find an anti-camout ribbed screwdriver very useful. A lot of cheap case fan screws start to strip easily but this saves the day:
I prefer using a magnetic screwdriver so I use one of these bits with a special adapter to achieve this.
2) Step drill bit. Useful if you break or loose your other drill bits. Or just don't have a drill like me. I connect this to a cordless screwdriver, works fine on thin metal.
3) "T" style hand tap wrench. + manual tap bits. I don't have one of these but I can see it would be useful to be able to move or replace a threaded screw hole. Problem is I don't know what to buy, maybe you guys can post some recommendations?
  #27 (permalink)
Old April 3, 2010, 05:31 AM
Mnpctech's Avatar
Great suggestions!
If you're going to paint your chassis, it's wise to dismantle everything. You will need pop-rivets to re-assemble it after it's painted.
YouTube - Pop Rivet Guide for PC Case Modding
1/4" length Pop-rivet is used most often and size we now stock for computer cases, 1/8" diameter, Gripe range .092" - .125"
Pop Rivets For Computer Cases
  #28 (permalink)
Old April 3, 2010, 09:09 AM
Sushi Warrior's Avatar
No hacksaw or fret saw? Hacksaws are great to cut bolts, rods, bars etc. and fret saws are like manual scroll saw, perfect for really fine designs.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
  #29 (permalink)
Old April 4, 2010, 05:02 AM
Mnpctech's Avatar
Good suggestion Sushi! I find myself using them to shorten machine crews a lot.
  #30 (permalink)
Old June 4, 2010, 08:17 PM
Mnpctech's Avatar
I'm getting a lot people asking off list, Asking which size to buy for 140mm size cooling fans.
You can use a 5.5" size Hole Saw Attachment. (140mm = 5.51181")
Amazon has good selections for 5.5" "Bi-Metal" Hole Saw attachment for your Power drill, HERE
Other Hole saw attachment sizes
80mm = 3” hole saw
92mm = 3.5” hole saw
120mm = 4.5” hole saw
Antec 300 modding or new case Bomberman07 Cases 21 April 4, 2009 05:25 PM
Dremel for Case modding serenity Cases 13 March 30, 2009 05:44 PM
Info in Modding a case? chouchou Guides & How-to's 7 November 3, 2008 07:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 07:23 PM
