Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old November 10, 2009, 02:23 PM
biff's Avatar
I don't care what we're doin' with 'em... if we're talking tools, I'm in!!
Good set of videos there Mnpctech! I'll have to go through them. I've been wanting to put a window in my Cosmos for a while now. Sure I can make a hole and fill it with acrylic but making it look 'finished' is another story. Looks like you're gonna be the guy to talk to.
Thanks.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old November 10, 2009, 10:41 PM
IRQ Conflict's Avatar
Two thumbs up! Loved the hole punch tool. Nice and clean. Word of caution to would be modders, deburring or not it will still cut you. Be careful! :)
-Rampage- Motherboard: Asus Rampage Formula CPU: Q6600 @ 3.2Ghz Cooling: OCZ Vendetta 2 Ram: 4GB OCZ Reaper HPC PC2-8500 5-5-5-15 @ 540Mhz Video Card: Sapphire Radeon HD 5870 @ 850/1200 Storage: Seagate Barracuda 4x 500GB Barracuda 7200.11 Raid 0 Power Supply: PC P&C Silencer 750 Quad Case: Antec P180B Monitor: Syncmaster 245T OS: Vista 64bit
Old November 11, 2009, 11:55 AM
Mnpctech's Avatar
Thanks for the comments and feedback guys
Originally Posted by dragoonxx View Post
I think I had seen a deburring tool on your website for one of your hole guides, where did you get that?
You mean the Roper Whitney Hand punch?
Roper Whitney No. 5 Jr Hand Punch kit available here
Hand punch (estimate $60 new, edit they raised the price to $80)
(for cutting fan mounting holes or enlarging existing fan mounting holes for rubber silencing grommets)
Hand Punch makes clean fan screw holes. No deburring.
Old December 1, 2009, 01:18 PM
dragoonxx's Avatar
no, it was a video you had hosted at one point in time for cutting holes... it was some one handed tool item...the video had you using something like a yogurt container for drawing a "perfect" circle on the top of the case
Old December 2, 2009, 04:20 PM
Navi's Avatar
Maybe for much larger cuts, an angle grinder would be useful? I have a sunbeam transformer, just cut out a fair sized portion of the mobo tray to help route cables.
eVga P55 FTW | i5 760 @ 4ghz | 4GB G. Skill Eco CL7 | eVga 9800GT | CM 690 II
Old December 2, 2009, 07:25 PM
biff's Avatar
FWIW Crappy Tire has (or at least had) a 'king size' dremel. I had to get an aarobour for it but it will turn 3" fiber disks with ease and not a lot slows it down. It's pretty much like a trim router with no base.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old January 13, 2010, 03:21 PM
dragoonxx's Avatar
found it, its a deburring tool...
McMaster-Carr
for those without to spend the money getting the expensive *but fast, I'd assume* punch
Old January 14, 2010, 01:18 PM
TopDogZero's Avatar
McMaster-Carr
Used this kind of tool at my work many times, it's good for cleanup of light burrs and gives a good finish but it’s not good on heavy burrs such as ones left by jigsaw’s on steel. Cleanup with rotary tool or file first for heavy burrs.
The tool is awesome for taking the sharp edges off metal blanks that you are going to work with and probably for sharp edges of plastics too.
  #19 (permalink)
Old January 16, 2010, 05:40 AM
Mnpctech's Avatar
Yes, and works great with plastic parts.
  #20 (permalink)
Old January 18, 2010, 10:40 AM
dragoonxx's Avatar
I personally own for my personal collection of mod tools...
1) dremel
2) drill and bits
3) files
planning on getting one of those deburring tools...now that I found it again
Antec 300 modding or new case Bomberman07 Cases 21 April 4, 2009 06:25 PM
Dremel for Case modding serenity Cases 13 March 30, 2009 06:44 PM
Info in Modding a case? chouchou Guides & How-to's 7 November 3, 2008 08:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 09:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 08:23 PM
