Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old October 18, 2009, 12:58 AM
Default How to switch motherboard without reinstalling Windows XP
As title...Present motherboard is a P35 Intel chipset based...moving to AMD 770 chipset.
XP has SP3 installed so the Repair option from XP CD is not valid.
Anyone done this before? Tia
Old October 18, 2009, 01:20 AM
It's usually a good idea to do a clean install if you're switching to a whole new platform, but you should be able to get by, by uninstalling all your Intel chipset drivers, shutting down, switching platforms, then booting back up again and letting Windows auto install all the necessary drivers.
Old October 18, 2009, 02:34 AM
Perineum's Avatar
I swap client machines all the time, but after the motherboard swap I do a repair install and it works for me, SP3 or not
Old October 18, 2009, 10:00 AM
"Quote This..."
You need to remove the intelide.sys file from windows\system32\drivers before you shut down and swap boards. Or it will crash on boot.
ASRock Z68, 8gb DDR31866mhz, 2600k @ 4.4ghz, GTX 590 Hydrocopper, 3 - 60gb Vertex SD's in Raid 0. Watercooled in a 650D
Old October 18, 2009, 10:38 AM
Shadowmeph's Avatar
really I didn't know that this is going to come in handy for when I replace a few mother board
Work in Progress
Folder : Parts so far
;ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6128 CPUs 2x NH-U9DO A3.inside a old hacked up case no side panels and a laptop harddrive , almost perfect for those cold winter months
BackOrdered
Parts needed;
A better case
Old October 18, 2009, 10:41 AM
Cheator's Avatar
This would be good.
The method I use is I isntall the chipset drivers of the new mobo before I install it. IT usually works. If its the same chipset you won't have an issue.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old October 18, 2009, 04:15 PM
Perineum's Avatar
I'm going to try sqeetards method next time, as that's much faster, providing I get a machine that is actually bootable to work on. Other than that, I take apart the dead machine, put in the new motherboard and parts and do a repair install.
The repair install was only not needed once in my experience when using completely different motherboards and it was a complete fluke.
Naturally if you're using a P5K-EM and then move up to a P5K-Deluxe it'll likely just boot up because they are not that dissimilar.
The one that gets me is when you boot up to do a repair install and you go to select the install after booting up off the WinXP cd and it says the parition contains "unknown" instead of "windowsxp". Not sure how to repair them....
Old October 18, 2009, 04:24 PM
gingerbee's Avatar
questions ( sorry ) with the squeetard way just remove that and it will boot so that you can load the drivers correct? ( I have only done it if it's in the same family say p35 to p45 )
Old October 18, 2009, 06:43 PM
"Quote This..."
I did the swap and computer would blue screen on loading xp. Found that solution online and it worked. Booted ubuntu and deleted that file, away it went.
Old October 21, 2009, 07:54 PM
clone63's Avatar
Quite a handy thread. Don't use Vista/7 but I wonder if it is any different.
switch needed Jim Display Units 7 April 1, 2009 03:54 PM
Router + Switch Mr. Gruntsworthy Networking 12 January 6, 2009 11:44 PM
ROuter switch v0maru Networking 2 December 19, 2008 11:44 AM
DVI Port Switch derrXIII Peripherals 0 August 15, 2008 01:31 PM
My Switch Mod kcksteve Networking 0 September 24, 2007 05:25 PM
