Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old September 25, 2009, 10:32 AM
Default Case fans to MB or PSU?
I have a HAF 932 and Corsair 850TX which I haven't opened either yet. Do I attach the case fans to the PSU or the MB?
Old September 25, 2009, 10:35 AM
i use both myself. depending on fan
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old September 25, 2009, 11:21 AM
Skyllz's Avatar
The HAF-932 fans are actually pretty quiet running at 12V. I hooked them up directly to the PSU in my case.
Is smoke supposed to come out of there?
Old September 25, 2009, 12:01 PM
Same here.
Old September 26, 2009, 11:07 PM
does it make a difference connecting the fan either on the MB or PSU?
Old September 27, 2009, 09:09 AM
martin_metal_88's Avatar
If the fan is PWM capable connecting it to the board will make speed change with temp of the sensor on the board. But, board suck at that the fan spin up most of the time. The best way is to get a fan controller or to short the fan to 5V. They will be pretty silent and good airflow as well.
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old September 27, 2009, 11:05 AM
Anyone know if it's a simple process to install for example a Zalman fan controller to an Antec 1200 which has several built in case fans all connected already?
Old September 27, 2009, 12:02 PM
Well the 12 hundred already have fan controller on the 3 front fan. If you want all fan to be on the controller, you should look at the Sunbeam Rheobus 6 channel. This is one of the best on the market with 30V on each channel. You can also remove the glossy plate and remove the led ( with some cutter ). If you stick with the Zalman, it`s pretty simple. Just put it like a CD drive and then plug every cable on the channel you cant`go wrong it`s pretty easy.
NCIX.com - Buy Sunbeam Rheobus Extreme Black 5.25IN 6 Fan Controller Blue LED Up to 30W Per Channel - RHK-EX-BK In Canada.
Ask for more.
Ask for more
Martin_metal_88
Old September 27, 2009, 01:05 PM
Actually Martin, ALL the fans on the Antec 1200 have controllers, the rear 2 and massive one on top are controlled on the back of the case. Still I am wondering if it would be a pain in the a$$ to somehow bypass the included controls and install the zalman.
Like this one:
::: Zalman, leading the world of Quiet Computing Solutions :::
Old September 27, 2009, 04:34 PM
rjbarker's Avatar
Because my Rig generates quite a bit of heat...I prefer all of my Fans to run at thier Max rated speed...no worries thier. As for whetehr I use the Mobo Fan Headers or directly to PSU basically boils down to Cable Management...however I can keep it all tidy...Fans that are positioned handy to Headers get plugged into the Mobo...those that are not..go to PSU...
Tri SLi "Procyon"
http://i30.photobucket.com/albums/c3...ant2/nice2.jpg
Evga 4.2 Ghz Club....
Tri SLi 580 MK11
http://i30.photobucket.com/albums/c3.../MK11Multi.jpg
Tri SLi 580 Vantage
http://i30.photobucket.com/albums/c3...ant2/60K-1.jpg
......Remember, keep your head up....and your stick on the ice
[FS] watercooled barebone (case,rad,blocks,PSU,fans,pump, ..) elninio Buy/Sell & Trade 1 April 28, 2009 09:23 AM
Case Fans? chouchou Air Cooling 3 October 24, 2008 07:49 PM
suggestions for case fans..... rob123 Air Cooling 18 August 13, 2008 09:19 PM
PSU fans - sleeve and horizontal? cegras Power Supplies 1 March 4, 2008 09:49 PM
Lots of goodies. 800W PSU, Fans, speakers. Cptn Vortex Buy/Sell & Trade 19 December 10, 2007 05:07 PM
