Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old September 27, 2009, 03:44 PM
martin_metal_88's Avatar
Originally Posted by Kleftiko View Post
Anyone know if it's a simple process to install for example a Zalman fan controller to an Antec 1200 which has several built in case fans all connected already?
If all fan already have a built in fan controller why did you ask if it would be hard???
Ask for more.
Old September 27, 2009, 04:59 PM
Maybe my question is not clear. I want to know how difficult it would be to re-route or re-wire all the existing case fans since they all already have exterior switches, to an after market fan controller instead. Will there be wire stripping/cutting involved? Are the wires simply plugged into the case's controllers and can be pulled and installed directly on the back of an after market fan controller?
In my situation, it would be nice to have ALL the fans controlled from the front in one convenient location instead of 3 of the switches located in the back. Also, the rear switches only have 3 settings (low/med/high) whereas a fan controller will give me more control with the knobs.
Old September 27, 2009, 06:23 PM
The wires are most likely just plugged in. I believe the fans are off-the-shelf Tri-Cools (aside from the big one), so it should be pretty simple to disconnect them.
Old September 27, 2009, 06:33 PM
Thanks Zero82z. Guess I'll have to shut it down and open her up to have a closer look.
Old September 28, 2009, 01:31 PM
rjbarker's Avatar
Should be simple...just a matter of re-routing cables....
Firestrike Extreme: 21.452
MARK 11: 32.530
[FS] watercooled barebone (case,rad,blocks,PSU,fans,pump, ..) elninio Buy/Sell & Trade 1 April 28, 2009 08:23 AM
Case Fans? chouchou Air Cooling 3 October 24, 2008 06:49 PM
suggestions for case fans..... rob123 Air Cooling 18 August 13, 2008 08:19 PM
PSU fans - sleeve and horizontal? cegras Power Supplies 1 March 4, 2008 09:49 PM
Lots of goodies. 800W PSU, Fans, speakers. Cptn Vortex Buy/Sell & Trade 19 December 10, 2007 05:07 PM
