Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old September 3, 2009, 03:05 PM
jcmaz's Avatar
Default Cable Management Tips
Does anyone have any cable management tip that they would like to share.
BTW, where do you put the big clump of wires coming out of the PSU?
THX
-Plato
Old September 3, 2009, 03:17 PM
Dwayne's Avatar
I don't see a case in the sig... from my experience the case is the key. You can make some bad cases look great with patience though. Other cases need to be modded some. I would do a google for cable management and have a look at some of the threads on other forums too. Have a look in the Worklogs here.
Me, I went to Princess Auto and bought some black zip ties, tie anchors and some black split loom. I didn't use much of the split loom, but the zip ties come in handiest for cleaning up the cables. The tie anchors are not that great, the ones I got, as the adhesive doesn't stick for very long in the warm environment of the case. It was worth a shot though.
That mass of cables, I got rid of it by getting a modular PSU Yeah, I know that is no help, but I couldn't resist.
Dwayne's Rig - eVGA x58 SLI LE : i7 920 @ 3.4 GHz : Mushkin 18GB mixed Silverline and Blackline : Corsair HX850W PSU : Corsair H100 : Corsair Obsidian 650D : eVGA GeForce GTX 580 : Creative X-Fi Extreme Music
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : Sapphire HD 6670 : Nmedia HTPC 1000B : Kingston 60 GB SSD Boot
Netbook - Asus eee
Tablet - Asus eee Transformer
Wife's Rig - Toshiba Laptop!
Old September 3, 2009, 03:36 PM
Prof. Dr. Silver's Avatar
+1 for Dwayne
And buy a Dremel! Cut some holes and VOILA!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old September 3, 2009, 06:20 PM
Silvgearx's Avatar
zip ties are the only way to keep those big wires tuck in place. and of course you need a case that can make it happen.
Old September 3, 2009, 06:28 PM
FiXT's Avatar
Hall of Fame
FiXT's New Cable Management Tip To Reduce Headache and Stress:
800D...
...Nuff Said
*Trademark Pending
Old September 3, 2009, 06:30 PM
bissa's Avatar
I just used the spare CD drive slots to put all the spare PSU cables into.
Old September 3, 2009, 06:45 PM
jcmaz's Avatar
Logisys CS-51WBK Black ATX Tower Case 4X5.25 2X3.5 5X3.5IN W/ 480W Front USB Audio
I have this POS case.
-Plato
Old September 3, 2009, 06:55 PM
Andy's Avatar
Originally Posted by jcmaz View Post
When I use to have a top mounted PSU in a case like that, I would put the optical drive in the second slot from the top. That would leave you a nice little nook above it to slip the mass of extra PSU cables.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
Old September 3, 2009, 07:04 PM
All you can do with that is either get a better case, modular psu or run the cables down the drive tower and tie them off.
Old September 3, 2009, 07:28 PM
FiXT's Avatar
Hall of Fame
I have a good sized scar on my index finger thanks to that case. I trying to take out one of the 5.25 rom covers. It was stuck, pushed a little too hard and it popped out really fast - slicing my finger on the razer edged metal
Required a few stitches and bloodied my car
I proceeded to drop kick the the damn the thing to the dumpster.
That said - it made an excellent case for cheap builds at the time
I suggest looking into maybe something like the NZXT Beta - It is an excellent case for a great price! Look really good, and has a few decent ways it could be wired to keep the insides tidy.
Cable Management help EaGle1337 Troubleshooting 9 January 7, 2009 06:07 AM
Cable Management :D Inik Cases 6 March 17, 2008 07:21 PM
Just another Cable Management Thread low351 Cases 2 March 17, 2008 05:48 AM
Cable Management Challenged [droc] Case Mods, Worklog & Gallery 7 February 10, 2008 06:59 PM
Cable Management Tips Cardboard box with DSL Cases 14 May 21, 2007 10:14 AM
