Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old September 7, 2009, 11:39 AM
Bojamijams's Avatar
With regards to the people tucking/routing the cables behind the mobo... Do you use taller standoffs? I don't have the height to get any kind of a connector to go under
Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
Video: 2x R9 290 @ 1050 / 1375 | ASUS VG248QE |
Audio: STX => Audioengine A5 / audio technica AD700X
  #22 (permalink)
Old September 7, 2009, 11:50 AM
Supergrover's Avatar
Run your wires first then install the mobo, molex connectors, 3pin, ect wont fit under while the mobo is installed.
R.I.P.
  #23 (permalink)
Old September 7, 2009, 05:21 PM
jcmaz's Avatar
In my case, i can tuck the cable behind the mobo tray thing.
-Plato
  #24 (permalink)
Old September 7, 2009, 05:32 PM
bare wires aren't good to run behind the motherboard incase they get poked ;)
  #25 (permalink)
Old September 7, 2009, 06:58 PM
Originally Posted by lowfat View Post
No. I believe it is a Cooler Master Cavalier or a model that looks similar to it.
Was curious because that tool less feature was originally seen on gigabyte cases..
  #26 (permalink)
Old September 7, 2009, 07:39 PM
lowfat's Avatar
Pretty sure the Cavalier is well older than Gigabyte has been making cases.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Cable Management help EaGle1337 Troubleshooting 9 January 7, 2009 06:07 AM
Cable Management :D Inik Cases 6 March 17, 2008 06:21 PM
Just another Cable Management Thread low351 Cases 2 March 17, 2008 04:48 AM
Cable Management Challenged [droc] Case Mods, Worklog & Gallery 7 February 10, 2008 06:59 PM
Cable Management Tips Cardboard box with DSL Cases 14 May 21, 2007 09:14 AM
