Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old September 3, 2009, 06:56 PM
jcmaz's Avatar
And i want to take out the stupid front door coz it blocks all my USB ports and the fragile POS window for a more solid one.
-Plato
Old September 3, 2009, 06:58 PM
Just buy a better case.
That is a budget case and its really a craptastic one.
Old September 3, 2009, 08:03 PM
lowfat's Avatar
How much room is behind the mobo tray? Is the PSU sleeved or not? If the PSU isn't sleeved you can get great cable management w/ any case as long as you aren't afraid of a drill/dremel. Just drill yourself some holes in the motherboard tray but under the motherboard so the holes stay out of view. Then run the cables underneath/behind.
An older system I did. No fancy sleeving. I had some more pics of systems w/ cheaper cases but I can't seem to find them.
Old September 3, 2009, 09:02 PM
Nice lowfat, that is darn clean.. Is that a Gigabyte case out of curiosity ... :)
Old September 3, 2009, 09:10 PM
Originally Posted by FiXT View Post
I have a good sized scar on my index finger thanks to that case. I trying to take out one of the 5.25 rom covers. It was stuck, pushed a little too hard and it popped out really fast - slicing my finger on the razer edged metal
Required a few stitches and bloodied my car
I proceeded to drop kick the the damn the thing to the dumpster.
That said - it made an excellent case for cheap builds at the time
I suggest looking into maybe something like the NZXT Beta - It is an excellent case for a great price! Look really good, and has a few decent ways it could be wired to keep the insides tidy.
That sucks about the scar :(. I myself have worked with a few crappy cases, cut yourself up a fair bit if you're not careful. I just built a pc with the Beta case, and it's awesome for the price, can't go wrong.
Old September 3, 2009, 10:15 PM
lowfat's Avatar
No. I believe it is a Cooler Master Cavalier or a model that looks similar to it.
Old September 3, 2009, 10:28 PM
jcmaz's Avatar
I do have some space (1-2 inches) behind the motherboard, which cables should i put behind it?
-Plato
Old September 4, 2009, 05:07 AM
Safearus's Avatar
Well, the ones that are not in use is a good start
Current Rig: "Έρεβος" -- English: "Erebus" ::
ASUS R.O.G. Crosshair III 790FX
AMD Phenom II X4 955 @ 3.6 Ghz (Feck...)
Coolermaster Hyper 212+
Thermaltake Armor
Corsair TX850W
Mushkin HP3 2x2GB DDR3
Samsung SATA DVD-RW
MSI GeForce GTX 275 Twin Frozr
  #19 (permalink)
Old September 4, 2009, 09:44 AM
lowfat's Avatar
ALL of them
  #20 (permalink)
Old September 4, 2009, 09:45 AM
There is also sometimes space between the power supply and back panel so you can stuff wires in there or they can sometimes have space above the psu as well.
Non sleeved cables are MUCH easier to flatten out.
Cable Management help EaGle1337 Troubleshooting 9 January 7, 2009 05:07 AM
Cable Management :D Inik Cases 6 March 17, 2008 06:21 PM
Just another Cable Management Thread low351 Cases 2 March 17, 2008 04:48 AM
Cable Management Challenged [droc] Case Mods, Worklog & Gallery 7 February 10, 2008 05:59 PM
Cable Management Tips Cardboard box with DSL Cases 14 May 21, 2007 09:14 AM
