Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old August 28, 2009, 09:33 AM
I was referring to your side panel, not the plexi. Is your side panel just a plain metal panel or does it have that grill thing?
When cutting with the jigsaw, make sure you have the right blade. Don't worry, your jigsaw is more than capable of handling that job.
Old August 28, 2009, 09:47 AM
The only thing my side panel has is the sound barrier on the inside.
Death to Apple
Old August 28, 2009, 10:02 AM
Plain side panel. That's good. Use your imagination to cut out your own design. Instead of just a plain square or rectangular hole, why not a hexagon or something of that nature. Actually now that I think of it, a hexagon shaped hole would look great on your cosmos case!
Old August 30, 2009, 01:18 AM
yaknow...just might,think i'm going to make a few cut outs, take some pics and start a work log..
Death to Apple
Old August 30, 2009, 01:20 AM
Safearus's Avatar
Just be careful with it. And you gotta make sure to file off the rough edges.
Old August 30, 2009, 01:41 AM
Thankyou. I won't forget.
Tool list:
Jig saw
Jig saw blades (metal and plastic)
Hand file
Square
anything im missing? I already have the drill press and dremmel.
Death to Apple
Old August 30, 2009, 05:25 AM
gingerbee's Avatar
22 tooth jigsaw will work but i recommend some up wards of 27 tooth cuts a lot easier. jmo
Old August 30, 2009, 05:28 AM
Thankyou very much.
Death to Apple
  #19 (permalink)
Old August 30, 2009, 10:45 AM
You can get a relatively cheap jigsaw from canadian tire. I think I paid around 25$ for mine.
  #20 (permalink)
Old August 30, 2009, 12:29 PM
gingerbee's Avatar
jobmate on sale is your cheapest I think ( canadian tire house brand i think )
Window for computer case silent1mezzo Cases 6 August 19, 2009 10:04 AM
HElp about window XP v0maru Troubleshooting 2 February 14, 2009 07:38 AM
office window CTA O/S's, Drivers & General Software 0 October 20, 2008 12:10 AM
ultimate install closed down after install prebent O/S's, Drivers & General Software 0 September 25, 2008 02:05 AM
Window Appliqués BALISTX Cases 5 October 15, 2007 08:21 PM
