Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old August 10, 2009, 04:54 PM
Default Sleeving :)
Well by the looks of things I'll be building a new computer in about a month, I was planning on ordering the case and PSU early to paint the case and sleeve everything prior to. I've ready guides and such and by the looks of it I need to buy.
- murderMod MDPC-X Psychopack | Sleeving Kits | murderMod
- Pin extractor? From MM or ncix? The sunbeam one looks decent as it has ones for several types of connectors.
Also given that I've never done this before, but I do catch on quickly. How much time would sleeving an entire PSU take (Probably the HX1000).
Old August 10, 2009, 05:11 PM
Sushi Warrior's Avatar
From what I've heard staples work much better than pin extractors If I was going to buy one I'd get the MM one for sure, all that NCIX stocks is the Sunbeam kit and something else and both of them fail. Staples may hurt a bit but they work better, are replaceable, and are cheap.
Old August 10, 2009, 05:15 PM
Your going to be looking at a lot of hours and days if you wish to individually sleeve all cables on a PSU.
Old August 10, 2009, 05:59 PM
SugarJ's Avatar
I'd say days. As in 3 or 4, a couple of hours a night. Your fingers will get awfully sore if you do more than that. At least mine do. Plan your runs, and only do the cables you need. I'd be tempted to get the MM extractor, I've got the sunbeam set, and it ain't great. The "staple trick" does work too. Get a cheap heat gun at Crappy Tire or Princess Auto or somewhere. A hair dryer doesn't cut it. Don't use a lighter, they put soot on your heatshrink. Although a lighter is handy for melting the ends of the sleeving so it doesn't unravel, if you don't have a hot knife.
Old August 10, 2009, 06:01 PM
Phobia's Avatar
Yeah, sleeving is a pain in the ass! I'm quite mad, I put my extractor tool in, and pulled the wire, and the wire came right out of the molex plug! I can't get it back in, or get the molex plug out either......... ;(
(whitty saying to be plagiarized at a later date)
Old August 10, 2009, 06:11 PM
Alright I'll buy a heatgun, CT has a 90 dollar one on sale for $35 with adjustable digital temp settings. I'll also grab the MM one if it's supposed to be better, no harm in making it easier.
Thanks for the time frame, my hands will hurt no doubt, but I plan to leave a lot of free time....in theory lol. Yeah I'll only do the cables I need to for now, sure gonna be some work though
Old August 10, 2009, 07:02 PM
Don't bother with a heatgun.
Get a small butane torch as they work way better and faster.
Old August 13, 2009, 02:49 AM
How would I go about removing molex connectors? Staples work with those as well?
Old August 14, 2009, 10:01 AM
lowfat's Avatar
I bought one from NCIX. Around $5 or something.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old August 14, 2009, 11:30 AM
SugarJ's Avatar
Ordered a Psycho-pack myself yesterday. My fingers are cramping up already in anticipation.
mmm sleeving lowfat Case Mods, Worklog & Gallery 31 October 20, 2009 11:53 AM
White Sleeving Phobia Power Supplies 2 July 5, 2009 01:26 PM
[WTB] Sleeving Job sinticfury Buy/Sell & Trade 13 June 7, 2009 10:11 PM
Cable sleeving, what a nightmare... Liu Kang Guides & How-to's 10 April 21, 2009 02:50 PM
Cable sleeving in toronto? elninio CPU's and Motherboards 14 June 5, 2008 07:05 AM
