<~----> Sleeving :) - Page 4 - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #31 (permalink)
Old September 28, 2009, 09:41 PM
Done and done. Probably took about 20 hours overall, Definitely much more efficient at it towards the end. I did all the case cables in a couple hours. I'd say, with some practice you could do a 24 pin in about 2 hours if you have the right tools. I think the first 6 pin took me 3 hours, then the rest were much shorter :)
  #32 (permalink)
Old September 28, 2009, 09:52 PM
SugarJ's Avatar
I just did all the non modular cables on a HX1000 for someone, took me about 5 hours. 1x24 pin, 2x 6+2 pin, 1x8 pin. 48 wires total. And yeah, the 24 pin was about 2.5 hours. You get in the groove.
  #33 (permalink)
Old September 29, 2009, 06:07 AM
Exactly, back tightening up? Who cares, you're motoring. I found the sunbeam tool worked better on the Corsair stuff than the murdermod. I've also got 2 modular 6+2 pins sleeved and a molex. That's as far as I went for now as I won't need more than that in the near future.
Did you finish your whole PSU yet Sugar?
  #34 (permalink)
Old September 29, 2009, 10:33 AM
SugarJ's Avatar
I've done everything on mine except the 24 pin. I'm waiting to mount the Classified board, to see how long the individually sleeved portion of the cable will be. I plan on sleeving groups of 4 or 6 from the psu to behind the mobo tray, then fanning out to the mobo connector. But I've got issues with the board I picked up on the weekend, it won't post. Going back to NCIX today.
  #35 (permalink)
Old September 29, 2009, 11:44 AM
Ah I went all the way, but yeah I plan on doing groups of 4 ties together so they flow out perfectly in a pattern, should look very nice. Sorry to hear about the board.
mmm sleeving lowfat Case Mods, Worklog & Gallery 31 October 20, 2009 10:53 AM
White Sleeving Phobia Power Supplies 2 July 5, 2009 12:26 PM
[WTB] Sleeving Job sinticfury Buy/Sell & Trade 13 June 7, 2009 09:11 PM
Cable sleeving, what a nightmare... Liu Kang Guides & How-to's 10 April 21, 2009 01:50 PM
Cable sleeving in toronto? elninio CPU's and Motherboards 14 June 5, 2008 06:05 AM
