Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 17, 2009, 12:54 AM
Angry Case temperature read out in Fahreheit
Help Please. OS Win XP Pro, Mobo ASUS P5Q Pro, CASE ANTEC P160. How can I set the temprature readout to Celsius? Is there a switch or is it a software set up?
We us the metric system here "Down Under".
Thanks
Old July 17, 2009, 04:53 AM
jcmaz's Avatar
Use CPU ID HWMonitor. I believe they have fahreheit
-Plato
Old July 17, 2009, 05:51 AM
gingerbee's Avatar
use realtemp 3.0 Real Temp - CPU temperature monitoring
Old July 17, 2009, 04:03 PM
rjbarker's Avatar
As we do here "up above".... ;)
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old July 17, 2009, 05:55 PM
Is CPU ID HWmonitor in the registry? Can you give me a bit more detail please?
Old July 17, 2009, 05:57 PM
gingerbee's Avatar
no it's software called HWmonitor free download check it out
Old July 18, 2009, 05:06 PM
Default ANTEC case P160 Temp readout
Thanks to all replying. Got the answer by using the old maxim "When all else fails, read the instruction manual".
There are 2 x 66cm leads that go to the mobo and HD from the top front of the case . On one there is a small switch with push for F and leave open for C. It is just above the bottom of the case.
As in life generally, it's easy when you know how!!
Temperature Too Low? curtispan CPU's and Motherboards 4 January 12, 2009 09:58 PM
Temperature problems =/ Dar_ell Air Cooling 3 December 29, 2008 07:32 PM
I need help with my e8400 temperature pSop CPU's and Motherboards 11 December 17, 2008 07:14 PM
Problem trying to get 'Read Only' file not Read only! bushwickbill Troubleshooting 5 August 10, 2008 12:41 AM
Temperature Thresholds??? mattydies Overclocking, Tweaking and Benchmarking 5 April 19, 2007 01:08 AM
