-   Guides & How-to's (http://www.hardwarecanucks.com/forum/guides-how-tos/)
-   -   duel monitors and mouse (http://www.hardwarecanucks.com/forum/guides-how-tos/19168-duel-monitors-mouse.html)
WolfBane June 21, 2009 04:44 PM
Ok i am running win 7 with duel monitors and a nvidia gtx 260 card :)
What my problem is , Is when i go to move my mouse cursor over to the second monitor i have to go all the way to the left then into the second monitor .
What i want to do is just slide the cursor from the middle of the monitors.
Ie: i am on left monitor and want to move cursor to the right monitor going to the right , and then move cursor to the left back to the left monitor .
Any ideals?
shayan288 June 21, 2009 04:58 PM
I think that like, when you go to the control panel place where you see two monitor (1 and 2) you have to click and drag one of them to the other side and it fixes it. Also you must adjust the liek priority thing that lets you chose which is your main one.
Prof. Dr. Silver June 21, 2009 05:05 PM
Shayan288 is absolutely right! I have had the exact same issue. Control Panel > Appearance and Personalization > Display > Adjust Screen Resolution :thumb:
WolfBane June 21, 2009 05:50 PM
+1 for you guys :0
Alls i had to do ids drag the monitors up and down or left and right :)
lol i was close just didn't do the drag thang !!1
Again this is one of the reaqsons i love this site:)
you guys rock!!!!!!!!!!
sswilson June 22, 2009 02:49 AM
Heh... you could have also physically moved the monitors..... ;)
Perineum June 22, 2009 01:38 PM
hahaha
enaberif June 22, 2009 01:57 PM
Or just swap video ports on the video card ;)
sswilson June 22, 2009 02:39 PM
I'll have to check to see if that works since the cat drivers work off of monitors rather than port. I'm not saying it wouldn't work, but I'm not positive. :)
WolfBane June 26, 2009 11:43 AM
Or i could just ask all you guys :) lol
napier July 7, 2009 11:29 AM
Dual monitors rocks, you will never wanna go back to single
