Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 16, 2007, 07:47 AM
Apollo4g's Avatar
Alright guys, links updated to NCIX to make it easier for you all
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old July 16, 2007, 08:08 AM
JayDee
Guest
Posts: n/a
Cool Apollo4g
You said in another thread that this was an existing guide that you had done in the past and would post here to help newbs such as myself
*tips hat*
Old July 16, 2007, 11:59 AM
Somed00d's Avatar
NCIX has some good kits as well.. this swiftech is what i bought and has many good components. direct canada usually has a bit cheaper price.. just buy from them or price match at nxic..
H20-220
http://www.ncix.com/products/index.p...cture=Swiftech
as well as their watercooling essential kits:
http://www.ncix.com/products/index.p...nufacture=NCIX (not great but a good basic start)
http://www.ncix.com/products/index.p...nufacture=NCIX (fairly decent)
also i have seen all 3 of these kits on sale in the sponsored deals..
Q6600 G0 @ 3.2ghz (965 chipset holding me back)
DFI Infinity P965-S
Gigabyte Geforce 8500GT
Buffalo Firestix FSX800D2C-K2G 2X1GB PC2-6400 CL5
OCZ XTC Active Memory Cooler
Seagate Barracuda 250GB SATA2
MCE Wireless Keyboard / Remote
Logitech X-530 Speakers
Swiftech H20-220 Water kit
Swiftech MCW30 NB Cooling
OCZ PowerStream 600W
Old July 16, 2007, 12:07 PM
Misoprostol
Guest
Posts: n/a
Thanks for doing those links :)
And I'm doing some testing on that Magicool CPU block that's included in the basic NCIX kit...
It seems to perform about as well as an APOGEE vanilla, and a little bit better than a STORM on a Core 2 Duo....
I'm impressed for $35. Expect to see a review up soon :)
Old July 16, 2007, 02:20 PM
lcdguy's Avatar
i'm a little hurt that i didn't see any links to ati coolers (i know were a small group) i would strongly recommend the DD TYEE if you can stomach the cost around 130-150 bucks. As for coolant don't forget water wetter that combined with some decent distilled of de-ionsed water is awesome. Finally my recommendation for clamps depends on the type of barb. For metal i would get some of those worm gear or jubilee type connectors for plastic or polypropelene barbs i would get the adjustable delrin clamps from DD.
Did you carpe your diem ?
Old October 16, 2007, 11:30 AM
Shadowmeph's Avatar
The only experience I have water cooling is automotive ( cars I have worked on lol) is there any other kinds of pumps that are cheaper or better that people could use like fish pond pumps things like that?
Old October 18, 2007, 01:23 PM
Shadowmeph's Avatar
I read some where (can't remember where ) that different (cpu and possibly gpu) blocks work better or worse with high volume/ lower volume pumps is this true? and if so which combination of lets say Intel cpu blocks works best with which pump. what I mean is the The MCP655™ pump is high pressure industrial pump, where as the Laing D5 12V Water Cooling Pump Is powerful enough to supply multiple cooling block solutions (CPU/GPU/Chipsets). does this really make a difference? only real thing I can see is the price
Also how does the V8 water block work http://www.stingerwaterblocks.mysite...hoto_page.html I read about it but I take it that you would have to Y connect it back into one line again?
Old August 14, 2009, 09:44 PM
Apollo, sir time for an update.. Masterkleer tubing at ncix is no longer carried. As far as that, only thing I would change is the gpu water block part, 8800 gtx is sort of old now..
Other than that, the guide still looks very strong and future proof.. Never notice your thread Apollo, probably one of the best suggestions I've seen so far..
  #19 (permalink)
Old December 2, 2009, 10:56 PM
IRQ Conflict's Avatar
Actually, the water blocks are no longer available either.
-Rampage- Motherboard: Asus Rampage Formula CPU: Q6600 @ 3.2Ghz Cooling: OCZ Vendetta 2 Ram: 4GB OCZ Reaper HPC PC2-8500 5-5-5-15 @ 540Mhz Video Card: Sapphire Radeon HD 5870 @ 850/1200 Storage: Seagate Barracuda 4x 500GB Barracuda 7200.11 Raid 0 Power Supply: PC P&C Silencer 750 Quad Case: Antec P180B Monitor: Syncmaster 245T OS: Vista 64bit
  #20 (permalink)
Old January 10, 2010, 02:09 PM
great tutorial post!!
Tags
guide , water cooling
Watercooling Guide Sticky BALISTX Water Cooling 1 October 10, 2007 11:00 PM
A beginner's watercooling guide from Tom's Babrbarossa Water Cooling 1 April 2, 2007 01:03 PM
Ma***Racers Guide to Online WaterCooling Stores cyberspyder Water Cooling 0 March 12, 2007 07:11 PM
Custom Appliques BALISTX Cases 6 February 26, 2007 11:58 AM
