Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old November 22, 2007, 06:37 PM
llama_egg's Avatar
Holy crap batman! Very nice guide! Time to begin sleeving everything in my computer! BWHAHA! xD
Old February 9, 2008, 11:31 PM
Patriote's Avatar
Originally Posted by MonkeyHood View Post
Very nice guide, was looking for something like this on XS. I just have a few questions. Where can you buy a solder, and how much do they cost? Where do you buy sleeves and heatshrink tubes? I've looked on jab-tech, but the shipping costs 3x more than the equipment. Is Jab-tech a reliable site?
Almost 3 months later, i answer your questions. Sorry!
You can get a solder iron @ home depot even @ Walmart. Depending of the quality, it's pretty cheap.
I personally love Jab-Tech. But yeah, if you are in Canada, you better place a big order with them so you will save on shipping. If you plan on just buying sleeving, then maybe you should consider buying sleeving kits or so in Canada which you can find @ www.ncix.com, Buy Computer Parts, Computer Hardware, PC Parts at Best Online Computer Shop - DirectCanada etc...
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old February 10, 2008, 07:05 AM
Babrbarossa's Avatar
Good you see you around Pat!
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old February 10, 2008, 12:11 PM
Patriote's Avatar
Thanks :) Been working a lot and someone took a new place in my life :)
• - Noctua NH-D14
Old May 23, 2008, 10:30 PM
And almost three months later I answer! Huzzah, the circle is complete!
The thing is, I just want to sleeve some fan cables. On NCIX, they have PSU sleeves which means I get a whole bunch and some are way too big. Is there any place to get thin sleeves and several feet?
EDIT: Wait, found one but it's blue. Not the end of the world, but I'd prefer black.
http://www.ncix.com/products/index.php?sku=28858
CPU: AMD Phenom 2 X4 940 Black Edition
Mobo: Gigabyte GA-MA78GM-S2H
RAM: 4*1GB DDR2-800 OCZ Platinum
HDD: 3*500GB + 500GB external
GPU: NVIDIA 8800GT
PSU:Corsair VX450W
Case: Corsair 800D
Old May 31, 2008, 11:18 PM
elninio's Avatar
Where can I get cable sleeving in Toronto.. theres no way I'm shipping some from the other end of the continent
Old August 23, 2008, 08:55 AM
Lithotech's Avatar
Great guide! Sure to help a lot of folks!
Fan tails are perfect for noobs to sleeving, the lines are short so use little material, and monetary risk of damage is very low!
A few tidbits of info from my experiences:
I have found the sleeving kits to be utter crap. You will rarely use the larger sizes, and there is barely enough of the smaller material to do a system. The nylon braid is not very good quality, and over priced. It doesn't expand or flex very well, lower heat rating, and dull colors.
All the cables in your computer (except the ATX line, and possibly the 12V 4 pin PCIe, EPS 8 pin) can be sleeved with 1/4 inch sleeving. I buy it in 10 foot lengths for less than $5 a pack (including tax) from here:
RP Electronics - Test Instruments , Power Supplies , Inverters , Electronic Project Kits and more!
Search for Flexible Sleeving. Burnaby, BC location. They do ship!
This stuff is aircraft quality.
I use 1/4 inch shrinktube with 1/4 inch sleeve, plenty of slack to fit over the sleeve and wire, and shrinks to a tight fit. 3/8ths shrink is a little big for this. The heatshrink tubing is a couple bucks for a 3 foot length.
A 10 foot pack is plenty to do an entire system including fans.
For the main ATX line, I use the 1/2 inch Split Braid sleeving. This stuff is great, you can apply it without taking off the connector which is a big risk if you don't get the wires back in exactly right (BOOM!). The only problem is you can't apply heatshrink on the ends, so I just use a ziptie. Also, it's only stocked in black.
PCIe lines will be a tight fit, so I use 1/4 inch split braid for this. Sata lines are difficult to remove the connectors, so I leave them alone. They route easy enough and usually hide perfectly so you don't see them anyway.
I have a variety of tools for removing the connectors, Sunbeam makes a kit with 4 or 5 tools, and there are also some new selections at NCIX (will be trying one or two in the near future).
To cut this stuff, I heat a box cutter knife with a propane torch, then cut the sleeve on a small piece of 2x4 wood. You get a perfect end every time with no fraying.
I keep a variety of colors in stock at all times, built up over time as I needed new colors or replenish stock. I keep it all in an old briefcase, so when I need to do sleeving I just grab my kit and everything is there.
eVGA 680i SLI (A1) P31
Intel Q6700 Kentsfield | Scythe Ninja-B | Antec Tri-Cool 80cfm
4GB (4x1024MB) Corsair Dominator 8500
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
Old September 29, 2008, 08:30 AM
Lithotech's Avatar
All NCIX carries these days is Mod Smart:
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
NCIX.com - Buy Modding In Canada.
You would be better off getting RP Electronics to ship to you. One of their 1/4 inch 10' packs will do, with a 3ft long shrinktube.
  #19 (permalink)
Old September 29, 2008, 09:08 AM
cwestwell's Avatar
I picked up my latest batch of heat shrink and goodies from Frozen CPU...Shipping sucked though
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
  #20 (permalink)
Old September 29, 2008, 05:02 PM
Since I'm local I just go shop at RP Electronics.
But the best bet is to just call around to various electronic shops and see if they have the sleeving.
Tags
guide
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 08:56 AM
Scythe Ninja Rev B. for those considering it - lots of pics 56k warning! low351 Air Cooling 17 March 28, 2008 08:28 PM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 09:51 PM
MDF Case build! 25K warning! chibi_man Case Mods, Worklog & Gallery 62 November 19, 2007 11:18 AM
Nvidia driver 158.45 overclock warning ragenrok Overclocking, Tweaking and Benchmarking 7 June 17, 2007 07:49 PM
