-   Guides & How-to's (http://www.hardwarecanucks.com/forum/guides-how-tos/)
-   -   Where can I find 800+ grit sandpaper? (http://www.hardwarecanucks.com/forum/guides-how-tos/18978-where-can-i-find-800-grit-sandpaper.html)
ADay2Long June 16, 2009 04:18 PM
Doing my paint on my case and I need 800 at least and + grit sandpaper for the final touches for wet sanding and I can't find anything higher then 600 ... tried Can Tire and Home Depot , any ideas anyone?
enaberif June 16, 2009 04:19 PM
canadian tire does have it.
perhaps that store was out.
its in the automotive section.
ADay2Long June 16, 2009 04:22 PM
Oh maybe, I was looking in the power tool section.
I guess since anything higher then 600 is for a distinctive finish ... thx man!!! I'll go right away!
ADay2Long June 16, 2009 05:06 PM
Well it was right next to the spray paint...makes sense lol, thx enaberif!
riflepwnage July 15, 2009 12:17 AM
either car shops or Canadian tires i bought 2000 grit from Canadian tire
Spikemaul July 15, 2009 01:57 AM
Acklands Grainger if there is one near you. They will have any grit that you need. :biggrin:
riflepwnage August 21, 2009 12:47 AM
Canadian tire is D place 2 go
Neolithium_Wpg August 21, 2009 01:06 AM
I got a bunch from WalMart when I did my case, they had 2000+ grit in their auto section as well
gingerbee August 21, 2009 04:19 AM
any automotive store
AdoP October 28, 2009 02:48 PM
Canadian tire automotive section, automotive sandpaper is much better for sanding metal/paint
