Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #31 (permalink)
Old June 9, 2009, 09:14 AM
gingerbee's Avatar
what about plaid is that stealing some one's idea ha ha
  #32 (permalink)
Old June 9, 2009, 11:56 AM
artistpavel's Avatar
I'm gonna paint mine this week, Canadian Tire carries Krylon and Dupi-colour, flat black or some metallic colour, not sure.
х58forLife
  #33 (permalink)
Old June 9, 2009, 12:36 PM
gingerbee's Avatar
looking forward to it
  #34 (permalink)
Old June 16, 2009, 09:21 AM
Hey guys planning on painting my haf932 interior matte black also. Just wondering, since it's the interior would i have to sand it? If so which sand paper to use? Can i just use the self etching primer, maybe 2 coats and then put the black matte finish coats as much as needed? I just don't want it to flake and scratch easily when installing and moving around in the case. Please let me know
Case: Haf 932
Cpu: i7 920 D0 @ 4ghz
Mobo: Evga Classified
Ram: G.Skill Tridents 6gb ddr3 2000
Video: Evga GTX 295 Red
Sound: Titanium Fatal1ty pro
PSU: Corsair Hx1000
Storage: 2x WD green 4tb & 2xWD Black 1tb, 1x SG 500gb
Cooling: Heatkiller 3.0, Mcp655, Gtx360 with 3 Ultra Kaze fans, Ek 150 w/cyclone
4x Side Fans: Yate Loon D12SL-12C
Controller: Kaze Master, Soundgraph veris premium htpc
Dual OS: Windows 7 64x
  #35 (permalink)
Old June 16, 2009, 09:49 AM
gingerbee's Avatar
no sanding i would just use the self etching primer and when your done painting it the longer you let the paint cure the lass chance you have of paint chipping off
  #36 (permalink)
Old June 16, 2009, 10:07 AM
I plan on doing the same thing to my haf932. I was thinking maybe a glossy black but with cathodes it would reflect too much. Maybe ill go with a metallic black though, not sure
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
  #37 (permalink)
Old June 16, 2009, 06:06 PM
ok i checked out canadian tire and asked the sales guy about self etching primer, he didn't know what i was talking about. I tried looking for it myself but couldn't find it myself, any specific brand and where can i get it? Maybe Rona or homedepot?
Case: Haf 932
PSU: Corsair Hx1000
  #38 (permalink)
Old June 16, 2009, 06:57 PM
gingerbee's Avatar
garage supply is where i buy plasti-kote i have had success with others but prefer this it's kinda pricey
  #39 (permalink)
Old June 16, 2009, 07:00 PM
TopDogZero's Avatar
Duplicolor has it and Canadian Tire carries Duplicolor but maybe they don't carry the primer.
Primers
  #40 (permalink)
Old June 16, 2009, 07:26 PM
ok great, ill try finding either of those 2 tommorow, maybe ill check another canadian tire nearby.? I don't have a car so i dont know many automotive stores
Case: Haf 932
PSU: Corsair Hx1000
Thinking about painting my case... Realityshift Off Topic 12 April 25, 2009 11:19 AM
Rig #1! Case Mod/Paint + Build chouchou Case Mods, Worklog & Gallery 37 December 15, 2008 09:05 PM
BALISTX's Guide to Painting your Case BALISTX Guides & How-to's 18 December 14, 2008 09:34 PM
New case - need paint! encorp Cases 14 May 1, 2008 11:10 AM
Question about Case Paint. Supergrover Cases 5 June 15, 2007 05:02 PM
