Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old June 3, 2009, 08:33 AM
gingerbee's Avatar
powder coating is the best but very pricey
  #22 (permalink)
Old June 3, 2009, 11:27 AM
Pelt's Avatar
This is turning out to be a very informative thread, and an inspirational one aswell. I think I'll start my own project soon using the tips provided.
http://lh4.ggpht.com/nightwarp/R7YQuMGt-JI/AAAAAAAADoQ/KVuthG6qJfE/s400/Supportourtroops-2.jpg
  #23 (permalink)
Old June 3, 2009, 12:01 PM
chrisk's Avatar
Folding Captain
Originally Posted by artistpavel View Post
I started customizing Xbox 360s few years ago, and made tutorial video:
artistpavel.com: Video: Painting Xbox 360 Faceplate In 3 Steps
back then I used automotive primer for a base coat available at Curry's Art Store, but later I discovered Krylon products, their stuff just sticks to any surface. You just have to make sure not to overspray it to avoid paint bleeding and build-up, it can't be removed.
this topic made me think if should offer custom art services for PC users, since I have all the experience, but for some reason was limited to Xbox community. If anyone wants to give it a try, I'm based in Toronto. The way I think it can work, you can send me the removable side panel and I will paint design on it, like I did with 360 faceplates:
Xbox 360 Faceplates - a set on Flickr
for example if I was to paint HWC rig it would have a beaver and red and gray decorative elements.
Just checked out your site...very nice work! You have talent!
Fold for team #54196
  #24 (permalink)
Old June 3, 2009, 04:30 PM
wetsand then primer ''yellow one fills gaps''
then wetsand again reprimer then paint you will get perfect results
i even wetsand after first coat of paint
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
  #25 (permalink)
Old June 4, 2009, 04:02 PM
IRQ Conflict's Avatar
I have to comment as well to artistpavel. Very, very nice. You've got teh skillz mate.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
  #26 (permalink)
Old June 6, 2009, 09:19 PM
artistpavel's Avatar
Thanks guys
Here are some pictures from one of the members from ocforums.com, just illustrates the whole point of painting the interior, notice matching colours, even stickers, he said it took him 2 cans of spray paint:
link
  #27 (permalink)
Old June 6, 2009, 09:50 PM
gingerbee's Avatar
nice great red and black thinking of the same color scheme for a while thanks for confirming that it looks great.
  #28 (permalink)
Old June 7, 2009, 08:19 PM
lowfat's Avatar
Originally Posted by quikgp View Post
ahhhhhhhhhhhhhhhh........light bulb!
damn. I've even painted many metal things before (and painted them properly, starting with primer). man...I'm a moron.
Thanks guys!
oh well. I'll do the install and touch up the paint that chips. Not like this is subjected to daily wear and tear anyways
metal doesn't need primer unless or you plan to expose the metal to a large amount of moisture or there is rust.
  #29 (permalink)
Old June 9, 2009, 04:54 AM
Way to steal my color scheme!
  #30 (permalink)
Old June 9, 2009, 08:43 AM
Cowboy's Avatar
if it was something obscure... like yellow and purple... I would agree.
but red & black... c'mon. That's almost universal.
Thinking about painting my case... Realityshift Off Topic 12 April 25, 2009 11:19 AM
Rig #1! Case Mod/Paint + Build chouchou Case Mods, Worklog & Gallery 37 December 15, 2008 08:05 PM
BALISTX's Guide to Painting your Case BALISTX Guides & How-to's 18 December 14, 2008 08:34 PM
New case - need paint! encorp Cases 14 May 1, 2008 11:10 AM
Question about Case Paint. Supergrover Cases 5 June 15, 2007 05:02 PM
