Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 16, 2009, 10:09 AM
Question Sleeving 24-pin ATX connector
All right guys. First off, I just bough this tool
NCIX.com - Buy Mod Smart Power Supply ATX Removal Tool for Removing 24 Pin ATX Connector Pins for PSU Sleeving - M-MINI-ATX2 In Canada.
for sleeving my 24-pin ATX connector. However, this is a REAL pain. I can't get a single wire out of the connector... There is something I am not doing right.
I am attaching a scheme.
So basically, you can see the ''pin'' connectors in black. Now, the blue thing is the plastic wich actually do definition of the pin... Hope I am not missing you. Now in red, you got my tool I purchase.
So where do I put my 2 ''needles'' from my tool: in the 2 yellow dots or in the 2 green dots?
Thanks a lot for the help... I just can't understand what is wrong with this
Hope you like my drawings
Old May 16, 2009, 10:21 AM
MacJunky's Avatar
Never used a tool like that but with a tiny screwdriver I have managed with what you marked as yellow dots.
Old May 16, 2009, 02:19 PM
All right thanks, I'll try with that.
Old May 16, 2009, 03:03 PM
SugarJ's Avatar
The tool goes on the sides of the connector, not on the top. If you can't get it, try using a couple of staples instead, and use some needlenose pliers to gently pry the wire out.
Edit: Found my picture.
Old May 16, 2009, 04:55 PM
ChuckleBrother's Avatar
Note that it usually helps to grab the wire by the end coming out and push it UP, basically away from removing it then giving it a gentle but firm tug.
Also take note that PSU connectors can be a right ***** to remove, I had no luck and instead got extenders(easier by orders of magnitude)
"...you play a mean banjo"
Old May 16, 2009, 05:34 PM
Phobia's Avatar
I just bought a sunbeam tool kit, and i must say, its much easier!
Old May 16, 2009, 05:41 PM
SugarJ's Avatar
I've got the same tool kit, sometimes it works, sometimes it doesn't. The staples work for me when the tool doesn't.
Old May 16, 2009, 09:24 PM
Argghh!! finally!! Thanks for all the answer guys, really appreciate it. All right so I finally figure... these tools do work well. Just finished my P4 connector (8pin CPU). It looks just great . I'll attack the 24pin in the current week. The only problem with these tools is that they don't come with any manuals, instructions of any kind... it suck when your purchase 5-10 bucks tools but just has to find out by your self how to do this... we were not born knowing how to sleeve cables
Old May 16, 2009, 10:48 PM
Google.
Tons of people have done this.
Old May 17, 2009, 09:44 AM
lowfat's Avatar
Cable Sleeving Guide - XtremeSystems Forums
w/ pics
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 02:59 AM
8-pin PCIe connector Dave510 Troubleshooting 13 April 24, 2009 08:54 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 05:46 AM
8 pin ATX cable the_bandit87 Troubleshooting 5 June 8, 2008 02:12 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 02:46 PM
