Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 17, 2009, 11:45 AM
Originally Posted by lowfat View Post
Oh man that is awesome. Thanks a lot!!!
Old May 17, 2009, 12:03 PM
That makes me want to spend 10 hours getting extremely frustrated, pissed off but in the end having a beautiful cable setup.
Old May 17, 2009, 05:00 PM
lowfat's Avatar
Actually it isn't that bad if you have a good tool. I have the tool that MurderMod sells and after using it a few times it gets pretty simple. Hell I even enjoy it and I can't stand doing any other sort of modding anymore.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 17, 2009, 05:39 PM
Good to know, although I'm not sure how I could sleep each cable on my HX 1000. All the modular ones are black and stuck together.
Old May 17, 2009, 06:35 PM
ChuckleBrother's Avatar
Flexforce cables? MM has some sata sized sleeving that will fit right over it
"...you play a mean banjo"
Old May 17, 2009, 08:22 PM
True. When you get the trick, with the right tool, it goes pretty quick.
Old May 18, 2009, 09:19 AM
These ones yeah. http://www.overclock.net/attachments...n-img_6320.jpg
What's the risk of doing this, if you missed one connector somewhere?
Old May 18, 2009, 03:35 PM
lowfat's Avatar
Can you just peel the wires away then just sleeve on wire at a time?
Queen of Dreams WIP
Big Lian Li
Complete
  #19 (permalink)
Old May 18, 2009, 04:33 PM
I have tons of extra ones (from an RMA) so I can sure try. Will get to it when I can.
  #20 (permalink)
Old May 19, 2009, 06:18 AM
Or try cutting the wires from each other with a razor blade.
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 01:59 AM
8-pin PCIe connector Dave510 Troubleshooting 13 April 24, 2009 07:54 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 04:46 AM
8 pin ATX cable the_bandit87 Troubleshooting 5 June 8, 2008 01:12 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
