Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 11, 2009, 06:16 PM
Rapid-X's Avatar
Default ps3 modding
thinking of upgrading a ps3 ,
i already jsut changed the harrdrive to a 350 gig seagate drive now im thinking about doing the graphics and speed and of course cooling any ideas??
Old May 11, 2009, 06:41 PM
You cant upgrade the graphics or speed of a ps3.
As for cooling you could maybe take it apart and put it in a custom case, maybe a pc case of some sort, and do some water cooling.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old May 13, 2009, 07:21 AM
Mr. Gruntsworthy's Avatar
Fail. the HDD is the only thing interchangeable in a ps3.
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
HTPC:
Case: Antec Minuet 350
CPU : Intel E4600 65nm Core 2 Duo @ 2.4Ghz 800MHz FSB
RAM : 3GB DDR2 667MHz
HDD : WD 80GB IDE
GFX : Sapphire HD4550 LP
PSU : 350W Antec
MoBo: ASUS P5KPL-AM SE
Old May 13, 2009, 07:33 AM
CMetaphor's Avatar
Agreed. Don't even try putting it in a different case, all the mounting points are way off. You're better off modding an XBOX 360 and putting it into that Lian-Li case (I believe encorp did this? correct me if im wrong...)
Old May 13, 2009, 07:35 AM
Chos3n's Avatar
Overclocking a Cell Processor ? ...
If you want to "upgrade" your PS3, then look for new revision. That means buy a brand new PS3 every time. Only thing they would change, is a cooler CPU, cooler GPU, new heatsink, bigger hard drive...etc.
I would never part myself from my 60GB PS3
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card MSI GeForce GTX 560 Ti Twin Frozr II
Sound Card ASUS Xonar DX
Old May 13, 2009, 12:02 PM
Lol lets get some ln2 on these things and go for records!
I love my 80gb ps3 as well. Its the earlier 80gb one with software ps2 compatibility and has a memory card reader and 4 usb ports instead of 2. Bought it used for $400 with cod4, motorstorm, and tiger woods 08 with 2 controllers. Far better than buying a new system with less features, no games, and 1 controller for the same price, not including taxes either
Case: HAF 932
Mouse: Logitech G9
Old May 13, 2009, 12:09 PM
Chos3n's Avatar
I bought mine for 559$ ... yup that was back then when the PS3 came out and was at 659.99$ (was at 699.99$ when the dollar sucked). Then, they were phasing out the 60GB since the new 80GB were coming. Wal-Mart had a 100$ rebate on it and since I used to work there... I got an additional 10% off ... :) So, 500$ before taxes.
Put any PS1 and PS2 games and they work!
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old May 13, 2009, 02:53 PM
Rapid-X's Avatar
i heard that u can make the remote ps button light up now with a qucik mod maybe i will see if i can find info to get the playstation 3 on the unit to light up
Old May 13, 2009, 10:34 PM
Waldie's Avatar
Yeah... I bought mine at 679.99... literally a week before they went up to 699.99. I counted myself lucky at the time. Now? Not so much. I love my PS3, and really love the backwards compatibility, four USB, integrated wireless, card reader, etc, etc. But damn that was expensive. The things we buy when we work at Best Buy in the games department and are in grade 12, with no concept of how much money you really need to save for university...
Still, don't regret it at all, PS3 is great
E8400 | EVGA 750i FTW | EVGA GTX 260 Core 216 SC | G.Skill 2x2GB DDR2-1000 | WD 640GB Black | Corsair TX750W | CM 690 | Acer H233H
Old May 14, 2009, 05:09 PM
Rapid-X's Avatar
lol sold a dual core e8400 with a 9800gx2 system to get this lol im not sure if i won or lost that one
fan modding kyle_L Air Cooling 9 May 3, 2009 02:26 PM
Where do you get your modding gear? The MAX Troubleshooting 11 February 1, 2009 08:39 PM
Modding idea.. metalcore Water Cooling 9 January 6, 2009 11:06 AM
keyboard modding cmac79 Peripherals 2 September 27, 2008 12:43 AM
X-Fi modding. turtletrax Audio 8 October 30, 2007 12:19 PM
