Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old April 21, 2009, 08:45 AM
Liu Kang's Avatar
Default Cable sleeving, what a nightmare...
I decided to try and sleeve all the cables on my power supply... I'm following all sorts of guides and tips, but not having any luck. Staples, sewing needless, etc.
I'm breaking pins, my fingers are killing me and I'm on the verge of insanity.
Any experience sleevers on here? Give me some advice... or better yet, a price to do all this work for me! :)
Cheers.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old April 21, 2009, 09:04 AM
get the proper tools for the job(kinda expensive though). You'll thank yourself.
Old April 21, 2009, 09:05 AM
Liu Kang's Avatar
I've seen them, but everywhere I read they say they break too easily...
LK
Old April 21, 2009, 09:14 AM
sswilson's Avatar
If a set of tools like this NCIX.com - Buy Sunbeam Power Supply Tooling Kit - PMTK In Canada. is breaking, then the person isn't using it properly. :)
Old April 21, 2009, 09:32 AM
Liu Kang's Avatar
As soon as my fingers stop bleeding, I will order them and let you know how well they work :)
LK
Old April 21, 2009, 10:49 AM
SugarJ's Avatar
That's the kit I use, but I found that the staple trick works better to remove the atx connectors. Those tools work well for the molex and fan connectors though.
Another little trick is to melt the cut ends, then they don't unravel. I use a BBQ lighter, very carefully.
Old April 21, 2009, 01:40 PM
BrainEater's Avatar
Here's my cable sleeving :
Quit yer whining.
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old April 21, 2009, 01:43 PM
HAH B.E., I jsut bought copper tubing to do just THAT!!! hahaha.
Old April 21, 2009, 01:45 PM
sswilson's Avatar
Yeah, but now you gotta break out the brasso to get it back to nice and shiny.... :)
Old April 21, 2009, 01:46 PM
Clearcoat...
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 01:59 AM
Bought my dream video card now a nightmare! xtreme1 Video Cards 14 November 30, 2008 02:35 PM
Cable sleeving in toronto? elninio CPU's and Motherboards 14 June 5, 2008 06:05 AM
Sata Data Cable Sleeving ChuckleBrother Storage 7 April 11, 2008 06:32 PM
MCW30 and DFI P965-s nightmare Somed00d Water Cooling 3 July 15, 2007 08:20 AM
