Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 31, 2009, 12:06 PM
Default ATI BIOS FLASH 3870 x 2
Warning,
DO NOT DO THIS IF
1. Your machine is overclocked
2. You dont have a video card to install for rescue operations
3. Your machine is not stable
4. You dont have a Floppy Drive
5. Your card runs fine and cool.
This is a method that worked for me and I am passing it on.
XP PRO 32,CAT 8.12 Drivers
Grab GPU-Z ,
get and save both stock bios(s) Master is 44kb ,Slave is 63kb
Get and run RBE_118
Tweak Fan profile, and 3d memory and clocks as desired, save as modmaster.bin and modslave.bin
Place 1.44 diskette into floppy drive, format as DOS boot disk, FAT format
Get atiflash, copy atiflash extracted files to floppy drive, copy modmaster.bin and modslave.bin to floppy disk.
Reboot computer, set boot order to see floppy drive first, reboot
At DOS curser, type specifically.... atiflash -ai
This will give all information on your videa cards as is.
type atiflash -s 0 stkmaster.rom
type atiflash -s 1 stkslave.rom
This will again save your stock bios(s)
To change bios(s)
type atiflash -p 0 modmaster.bin
then
type atiflash -p 1 modslave.bin
then remove floppy disk and reboot. There is a tut on making a USB thumbdrive around, for those that dont have a floppy drive it is an option.
Good Luck
Code:
how do you flash the bios on a gpu? Gameplaywarrior Guides & How-to's 8 October 20, 2008 05:41 PM
Updating BIOS on GA-EP45-DS3L failed, how to access back up BIOS? Kayen Troubleshooting 5 August 7, 2008 07:31 PM
Safest BIOS Flash Method? mattydies CPU's and Motherboards 11 May 20, 2008 07:31 PM
Help with bios hot flash ebdoradz CPU's and Motherboards 0 February 7, 2008 11:52 AM
Bios Flash, Please Help !! Unklmo Troubleshooting 5 October 22, 2007 05:55 PM
