Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old March 29, 2009, 11:31 AM
Realityshift's Avatar
Walmart sells 3 cans of memorex canned air for $18, price club also sells 3 cans for like $14. Those are the 2 places I usually buy mine. Never buy it in single cans its always more expensive.
The Builders Hammer
  #22 (permalink)
Old March 29, 2009, 11:37 AM
ipaine's Avatar
If I recall Costco sells them for $20 for 6 cans, best deal I could find anywhere. At least I believe it was $20.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
  #23 (permalink)
Old March 29, 2009, 12:04 PM
Yeah costco/price club is usualy the best place to pick them up but you also need to have the stupid card to get in...
The Builders Hammer
  #24 (permalink)
Old March 29, 2009, 03:22 PM
i used to use cans of compressed "air" besides being ridiculously over priced i didnt like breathing that crap in such a closed place.
now i use a paintbrush. its some kind of animal hair and not repeat not one with artificial bristles. takes quite a bit longer but it gets to everything.
cheers
rob123
  #25 (permalink)
Old March 29, 2009, 04:05 PM
Digikid's Avatar
Originally Posted by Squeetard View Post
I use a vacuum.
BAAAD idea. Vacuum can build up a static charge and can zap your PC parts and kill them.
That and it is always possible to accidentally suck up a jumper or two.
Rob123: That would be camel hair.
  #26 (permalink)
Old March 29, 2009, 04:16 PM
crispex's Avatar
Canned air + vacuum = a good idea, says I.
Though I wouldn't be putting the vacuum too close to the actual computer. I'd just use it to grab the dirt the can knocks loose...
  #27 (permalink)
Old March 29, 2009, 04:44 PM
Canned air makes good people deterant when your busy with a long gaming session and someone wants to annoy you. Flip the can and freeze some vital part of their skin =) and then carry on gaming.
The Builders Hammer
  #28 (permalink)
Old March 29, 2009, 04:59 PM
you can get compressed air cans almost everywhere where they sells computers and electronics.
  #29 (permalink)
"Quote This..."
Freeze their nuts to the chair then kick the chair over.
  #30 (permalink)
Old March 29, 2009, 06:02 PM
crispex's Avatar
But...but the idea was that you're the one in the chair, making them go away.
Why give up a perfectly good chair?
...and what if it's a female?
