<~----> Compressed Air...? - Page 2 - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 29, 2009, 08:35 AM
Originally Posted by mlauzon View Post
Again, don't own a vacuum, and would not put one into a 5K computer even if I did!
You don't own a vacuum?
And why wouldn't you use one in a computer? They don't cause any problems.
Originally Posted by chriskwarren View Post
Forgot to mention; if you have not done this before, don't worry about it. Just shake the can, and do short bursts (ie. don't just do one long spray).
No do NOT shake the can.. geezus why do people do that? Its not spray paint. Read the directions it even says do not shake.
Old March 29, 2009, 08:41 AM
chrisk's Avatar
Folding Captain
Really? Been doing that all along lol
Fold for team #54196
Old March 29, 2009, 08:51 AM
Phobia's Avatar
Enaberif beat me to it. it says right on the can "Do not shake" :P
Old March 29, 2009, 08:52 AM
chrisk's Avatar
Folding Captain
Yeah I know...my bad...had to go look too.
Just goes to show that even if you use the stuff wrong its no biggie lol.
Old March 29, 2009, 08:55 AM
Shaking the can disrupts the liquid and doesn't allow it to work as long. It does the same thing as when you use it, so if you want your cans to last longer.. QUIT SHAKING THEM
Old March 29, 2009, 09:02 AM
A question: what does everybody think of the "new in thing to do" by scenting compressed air..?!
Old March 29, 2009, 09:10 AM
punk_zappa's Avatar
How much is a can of compressed air? One can is not enough if you have 2-3 systems to clean. I have this small compressor I bought from Princess Auto years ago. I bought the attachments (hose, blower and fittings) and this is what I use to clean my systems. If you will be cleaning your system frequently I suggest this setup rather than buy a can of compressed air every time you want to clean your rig/s.
Old March 29, 2009, 09:13 AM
Originally Posted by punk_zappa View Post
How much is a can of compressed air? One can is not enough if you have 2-3 systems to clean. I have this small compressor I bought from Princess Auto years ago. I bought the attachments (hose, blower and fittings) and this is what I use to clean my system. If you will be cleaning your system frequently I suggest this setup rather than buy a can of compressed air every time you want to clean your rig/s.
Problem with air compressors is a lot of them use oil and unless you have air conditioners in place to make sure the air coming out is fairly clean, they are very bad to use as sometimes the dirt and particles in the compressor will get onto your components and could possible cause failure.
  #19 (permalink)
Old March 29, 2009, 09:18 AM
punk_zappa's Avatar
I've been cleaning my rigs with this for about 3 years now and every time I do it I check for water or any particles that may have come out of the compressor and so far everything is good. I also drain the compressor after use.
  #20 (permalink)
Old March 29, 2009, 10:11 AM
sswilson's Avatar
I don't use compressed air for fear of condensation. All I use is a vacuum cleaner and a shaving brush to get the crap out of tight spaces like heatsink tines.
