Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old February 18, 2009, 10:26 AM
Default Antec Led Tricool Fan mod help!
I have 3 antec LED tricool fan at home, i would like to add them in my cooler master Storm Sniper case... (one in bottom and 2 on the side window) but i would like to have the ability to turn On / Off the led on the fan while keeping fan running.
So is there any way to mod those fan to be able to connect the led separately to the power of the fan.
There is 5 wire that come out the fan :
3 wires (black, red, yellow) that goes to the 3 speed switch.
2 wires (black and red) that go to the 4 pin molex connector.
Is it possible to do ?
Thanks for any help!
Old February 18, 2009, 10:30 AM
donimo's Avatar
You would have to splice the switch to the leads on the board inside the fan, if you look the LED's go to their own spots on the board, you need to put a switch inline with one of those wires.
or remove them from the board and have them seperatly powered, that is assuming they are 12/5V
Mobo MA770-UD3P CPU 7750BE RAM:4x1GB OCZ Gold GPU:XFX HD6850 Black Edition @820/4400MHz Case: Antec Sonata III PS: Corsair HX620
Old February 18, 2009, 10:57 AM
Not possible LEDs are soldered directly onto the fan.
Those wires have nothing to do with the LEDs.
Old February 18, 2009, 11:01 AM
donimo's Avatar
or you could do what I said, but I admit it will be a massive PITA for the effect your going for.
Old February 18, 2009, 04:06 PM
I think i just install it without the ability to turn off the led of this fan... that's it...
i could always turn off the 2 big 200 mm fan that come with the case...
later i will buy a proper fan.
Old February 18, 2009, 04:09 PM
Just cut off the leds :P
Old February 21, 2009, 07:48 AM
Follow the previous post or leave them alone use them as is.
Cambridge,ON
Asus P8P67 Vanilla
2500k@4700 (4.7Ghz)
Ripjaws 1866
Hyper 212+ & 2 Excalibur fans
EVGA GTX460 Superclocked
Part# 1G-P3-1372-TR
Antec P280-all tricools low spd & 2 on front.
Seasonic S-12 650 Energy +
[WTB] Antec 300 (or 900) divertiti Buy/Sell & Trade 3 January 1, 2009 02:35 AM
Antec does it again ha! Sniper Cases 13 November 2, 2008 01:52 PM
FS: Antec 900 Jon_di2 Buy/Sell & Trade 3 September 13, 2008 04:19 PM
Antec 900 and WC LooseCannon Water Cooling 13 March 16, 2008 04:44 PM
Antec 900? richuwo11 Cases 41 January 13, 2008 07:26 PM
