Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old February 12, 2009, 05:45 PM
Shadowmeph's Avatar
Default I have know clue how to overclock my CPU
This is embarrassing, I looked at a couple of the Guides and became totally lost on how to overclock my cpu.
I look in my Bios and am pretty much lost because it looks so different then the guides Bios.
Need less to say I have know idea where to start
Work in Progress
Folder : Parts so far
;ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6128 CPUs 2x NH-U9DO A3.inside a old hacked up case no side panels and a laptop harddrive , almost perfect for those cold winter months
BackOrdered
Parts needed;
A better case
Old February 12, 2009, 06:33 PM
Could you post a couple of shots of teh bios, where memory timings and cpu speed, voltages?
Basically, increase cpu/nb volts, and then increase cpu FSB speed, boot into your OS, and test away...
Old February 12, 2009, 06:36 PM
3.0charlie's Avatar
That's about it on a DS3L...
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old February 12, 2009, 06:50 PM
Yeah, maybe some mem tweaking...
Old February 12, 2009, 06:54 PM
3.0charlie's Avatar
True, keep a close eye on that mem speed since you have DDR2-6400 to run with that E8400. Drop that ram multi to 2.00, and have fun!
Don't be shy to raise the NB volts at +0.3V - make sure you have plenty of airflow, the board can handle that no problem.
VCore max. 1.40V.
Major Vdroop on that board though.
Supergrover's Avatar
I tend to work one first then the other, overclock the cpu then work on the ram. Then see what is stable out of those numbers.
Old February 12, 2009, 07:13 PM
Shadowmeph's Avatar
ok thanks people. I will try
Work in Progress
BackOrdered
Parts needed;
A better case
Old February 13, 2009, 12:46 PM
Shadowmeph's Avatar
ok well I still don't know what I am doing I go into the mit settings in my Bios and all I see is ( this is a pic of a Bios I found googling I am not sure how t oget a pic of my own bios otherwise I would post that pic) of course my cpu clco ratio is at 9x and I also have some setting under the clock ratio that when I open it it shows I can bump my cpu up to 3.16ghz .. other then that I am not sure what to do I want to go as high as I can ( stable)
Work in Progress
BackOrdered
Parts needed;
A better case
Old February 13, 2009, 01:52 PM
CPU host Clock Control, set to enabled, Will allow you to adjsut the value jsut below...which is FSB. Voltages are just below, on the bottom half of teh page.
pic can be taken with a digi-cam/webcam, cellphone...
Old February 13, 2009, 04:27 PM
Shadowmeph's Avatar
ok that makes sense so what is the average to go from the setting is at 333 so how far should I boost it up to 400? that which program do I test for stability / heat and for how long? oh and by the way thank you
Work in Progress
BackOrdered
Parts needed;
A better case
Tons of hdtvs, no clue which to choose Jonwall Display Units 13 December 26, 2008 05:38 AM
Help overclock Kappy Overclocking, Tweaking and Benchmarking 10 September 2, 2008 02:58 PM
overclock evzonas CPU's and Motherboards 2 August 31, 2008 05:49 PM
ram overclock Tazer-[X] RAM 13 August 3, 2008 10:54 AM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 05:32 PM
